Converting Cat5e phone jacks to network lines - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 07-14-2013, 12:48 PM
jautor's Avatar
Quoted: 1217 Post(s)
Liked: 780
Note that because all the cables punched to the phone block are wired in parallel, so in order for the toner to work, each cable must be yanked off the phone block (otherwise they will all beep...). I would suggest taking one off at a time and toning out the far end of each. Then you can stop disconnecting once you find the one(s) you care about. Or you can do it right and yank all of them so you can label them once and for all...
jautor is offline
post #32 of 32 Old 07-14-2013, 05:01 PM
sarahd's Avatar
Thanks again for your assistance. I visited the attic trying to dig below the insulation in search of the cable in question. Not much fun and unsuccessful to boot. I bought some RJ45 connectors and picked 3 cables from the phone hub that were not the right ones. Seven more to go.
I think I might just bite the bullet and hire an expert to get the job done right. My expertise is in accounting, not wiring, so I can appreciate what an expert brings to the table. Hopefully an hour service call can identify the cable in question and have the company label the other cables as well.
At least I know more about the cable than I did a day ago so allis not lost.
sarahd is offline
Reply Home A/V Distribution
