Elan HDC 2000 Acting up - AVS Forum | Home Theater Discussions And Reviews
Old 05-22-2011, 10:02 AM - Thread Starter
Guitarnie's Avatar
Working on a older system with a HDC 2000 ver 3760 with 6 zones. Power supply took a crap last year had that repaired, reinstalled and has been fine until AT&T / U-Verse guys attempted to install a system and failed.
I pulled the unit because it was dead. Bench it and it powered up and seemed OK.
Now I have reinstalled it, it powered up and was acting as it should allowing me to change sources, etc.
I tried a second zone and it shut down. Began cycling through version #'s and then stalls at "Waiting IR Card".
I pulled the IR card "IR Card Problem", reinstall IR card, reboot and acts like it is OK. I can manually change zone sources, volume,etc.
Then it starts scrolling
MCU VER 3-760 M
IR VER L039
IR LI6 P010
R R
Waiting IR Card
Waiting IR Card
Waiting IR Card
Waiting IR Card
Waiting IR Card
and randomly will display
Reading IR Card
and displays
MCU VER 3-760 M
IR VER L039
IR LI6 P010
Waiting IR Card
and randomly displays these after the
MCU VER 3-760 M
IR VER L039
IR LI6 P010
R M
G D
I A
R R
E
9
N R
Version Changed
E H
T C
V 0
and more
Anybody have clue what's going on with unit?
Thanks in advance,
Arnie
Guitarnie is offline
Old 05-23-2011, 05:23 PM - Thread Starter
Guitarnie's Avatar
Anybody? Bad IR card? Bad unit? Any direction would help. I don't know any installers that know this system.
The situation sucks the customer has no doorbell in her Mac Mansion.
Selling an entire upgrade is not going to be easy, plus all the wiring is a cluster f#$% that I would not want to dive into.
Old 12-01-2012, 09:41 PM
manish k's Avatar
I am facing similar issue with elan HDC 1000 ,
It flickers between power and standby mode
MCU REV 3-340
IR REV REV --
manish k is offline
