HDMI 1x4 Splitter with CAT5e/6 Outputs - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2011, 09:37 AM - Thread Starter
sbenus's Avatar
So I found this to be a much cleaner solution to my distribution problem than buying a bunch of baluns. The only issue I have is that I have not found anybody that makes one with IR control as well.
Anybody know of one that includes IR?
Here's the kind of splitter I'm looking at:
http://www.kanexpro.com/item/?id=HD4PSPE
sbenus is offline
Old 07-11-2011, 10:58 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Vin
Vin is offline
Old 07-11-2011, 11:06 AM - Thread Starter
sbenus's Avatar
I forgot to mention that I needed to use one cat5 cable per output, not two.
sbenus is offline
Old 07-14-2011, 02:49 PM - Thread Starter
sbenus's Avatar
Originally Posted by ishmael62 View Post
This unit should fit your needs: http://sewelldirect.com/HDMI4PortsSp...erbyCat5x1.asp
I don't know if it carries IR as well, but I read about an Injectir at Engadget which should work through this as well.
I've worked with Sewell Direct before and they do really good at helping you finding what you need and helping if you run into any issues with the product.
u rock! thanks
sbenus is offline
Old 07-19-2011, 03:33 AM
Lim
Lim's Avatar
Any idea on the receiver unit (not included), which decodes the signal back into HDMI for direct connection to a television? It is not included in the package.
Lim is offline
Old 07-21-2011, 10:36 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
The receiver units will be available when the splitter itself becomes available...according to monoprice tech support.
Vin
Vin is offline
