CCTV Cable Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-14-2011, 01:50 PM - Thread Starter
ishmael62's Avatar
I hope I am in the right area...
I'm installing a CCTV system in my home. 4 cameras, 1 DVR. It is pretty basic. I found what I want for cameras and DVR but I have read that a lot of issues arrive with the cables that you run. I don't want to spend too much money on it and found RG59 Cable online.
Has anyone had experience with this cable? Is this cable a good price?
I found more expensive cable online but wanted to get some advice before a spend a hefty chunk of cash on cable. Also, you probably know it would be a hassle to install the cable just to find out you have to tear it out because it doesn't work right.
Thanks for your help!
ishmael62 is offline
post #2 of 7 Old 07-14-2011, 02:02 PM
fletch999's Avatar
It all depends on what type of cameras you have. Also, what about power? If the camera uses 59 to move the video around, it likely needs at least a 2 conductor wire to power the camera.
fletch999 is offline
post #3 of 7 Old 07-14-2011, 02:50 PM
Colm's Avatar
Liked: 94
Yeah, and the cable the OP is considering is a siamese cable with power conductors...
Colm is offline
post #4 of 7 Old 07-14-2011, 03:01 PM
cctvtech's Avatar
Quoted: 90 Post(s)
Liked: 72
It's good that the cable has 96% braided copper shielding (1/2 of CCTV requirements) but there is no mention of the center conductor, which should be 100% pure copper.
Be careful!!! Some cheap CCTV cables use copper-clad steel center conductors, which are cheaper but lose too much signal over distance. Steel is not a good conductor.
Be seeing you!
cctvtech is offline
post #5 of 7 Old 07-14-2011, 03:19 PM - Thread Starter
ishmael62's Avatar
You are right. I forgot to mention that the indoor/outdoor cameras use RG59 and need power. That is why I thought this cable might work well because it is siamese cable which has both the video and power connections.
post #6 of 7 Old 07-14-2011, 04:44 PM
Colm's Avatar
Liked: 94
How long is the longest cable going to be? Are the cameras color or black and white?
Colm is offline
post #7 of 7 Old 07-15-2011, 12:06 PM
cctvtech's Avatar
Quoted: 90 Post(s)
Liked: 72
You can probably use CCA cable for runs up to a couple hundred feet but be aware that aluminum cable is not as flexible as copper so keep large bend radii.
Be seeing you!
cctvtech is offline
Reply Home A/V Distribution
