Send and control video to several TV's a few hundred feet apart - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-12-2011, 01:02 AM - Thread Starter
willp2's Avatar
I've trying to find out what options there are for getting video to several TV's that are pretty far apart. The furthest will be as much as 200' away from the source.
HDMI and HDMI over CAT6 don't seem viable from what I have seen. Any other options come to mind? I was toying around with the idea doing a video over IP system but I really don't know if that is even practical. I'd like to be able to deliver several video sources to each TV in the end.
Any advice would be greatly appreciated.
willp2 is offline
post #2 of 7 Old 10-12-2011, 06:58 AM
sold's Avatar
There's HDBT based stuff around that claims to do what you want e.g. http://www.atlona.com/ATLONA-HDMI-EX...-SUPPORT..html - matrix switches as well - http://www.atlona.com/Atlona-HDBaseT...CAT5e-6-7.html
Other companies should have similar products, was just the first that came to mind.
sold is offline
post #3 of 7 Old 10-12-2011, 08:19 AM - Thread Starter
willp2's Avatar
Great thanks. That look like exactly what I'm after. I'll start doing some research on HDBT and Atlona.
Thanks again.
willp2 is offline
post #4 of 7 Old 10-13-2011, 10:25 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You'll spend a lot of time researching this, trying to figure out a solution. I think this type of install is done fairly routinely in the commercial world. Talk to some local commercial AV installers. Might be worth a consultation fee, and you will likely be able to purchase the equipment through that installer below MSRP.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #5 of 7 Old 10-14-2011, 01:43 PM - Thread Starter
willp2's Avatar
Thanks I'll do that. Trying to keep it inexpensive but it's worth some calls to the local pros. Maybe someone will take pity on me
willp2 is offline
post #6 of 7 Old 10-14-2011, 01:55 PM
wyen78's Avatar
Originally Posted by willp2 View Post
Thanks I'll do that. Trying not to keep it inexpensive but it's worth some calls to the local pros. Maybe someone will take pity on me
If you're trying not to keep it inexpensive you can send me a couple grand. I have no expertise in this area, have no idea how to set up what you want, and basically am completely unqualified. But it will add expense if that's what you're after
wyen78 is offline
post #7 of 7 Old 10-14-2011, 02:19 PM - Thread Starter
willp2's Avatar
Doh!!
Checks in the mail. I look forward to your invaluable input.
willp2 is offline
Reply Home A/V Distribution
