Yamaha RX-V867 coaxial input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-14-2011, 04:36 PM - Thread Starter
maesterjay's Avatar
I just got rid of my cable boxes because it was too expensive, I switched to basic cable and now the coaxial comes straight from the wall. Is there an input to put that into the V867 and then it could put it to the TV by hdmi like usual? If not what kind of setup/options do I have at this point?
maesterjay is offline
post #2 of 3 Old 10-14-2011, 05:31 PM
cavu's Avatar
No.
You are now using the tuner in the TV and you'll have to run audio back the the AVR from the TV.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 3 Old 10-15-2011, 01:36 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Yep, assuming your TV has a digital audio output, you can run a separate cable from the TV back to the receiver. If the TV is very new, that receiver supports the HDMI Audio Return channel - so it would flow over the HDMI cable without a separate wire. Only if the TV also supports it (part of HDMI v1.4).
Jeff
jautor is offline
Reply Home A/V Distribution
Yamaha Rx V867 Receiver
