Rackmount switch with power and sockets in the rear - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 10-24-2011, 10:23 PM - Thread Starter
ktrdsl23's Avatar
Why does it seem that all rackmountable switches have the ethernet sockets and the power outlet on opposite sides? Don't most people want all their wires/cables in the back of their racks?
I was all set to buy this model until I realized that the front would have all my ethernet cables sticking out. Isn't that pretty ridiculous since almost all people have racks with their cables in the back?
Does anybody know of a gigabit switch where the front would just have indicator lights and the back would house all the spaces for cables?
ktrdsl23 is offline
post #2 of 27 Old 10-24-2011, 11:26 PM
Colm's Avatar
Liked: 94
No, network engineers want them in front so they can be changed easily. They aren't concerned about esthetics.
Colm is offline
post #3 of 27 Old 10-25-2011, 03:11 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Can you turn it around and mount it to the rear rack rails, and put a blank plate in front of it?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #4 of 27 Old 10-25-2011, 07:32 AM
fcwilt's Avatar
Quoted: 43 Post(s)
Liked: 26
There is a company or two that cater to the "Home Theater" crowd and make switches like you are looking for - I remember seeing the switch but I cannot remember the name.
Regards, Frederick C. Wilt
fcwilt is offline
post #5 of 27 Old 10-25-2011, 07:41 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Mounted to the rear rails, a switch would be flush with the back of the rack, possibly causing issues. But, I think this is how it's usually done, unless you have the money for the fancy switch.
39 cent stamp has suggested to add a third set of vertical rack rails, if rack depth allows, toward the rear of the rack, perhaps 6 inches from the back. This allows for the addition of small, unusual components and takes advantage of the voids behind the components. I did this in my very deep rack, and it works great.
post #6 of 27 Old 10-25-2011, 07:42 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
And, since switches are usually shallow, you can probably mount it directly behind another component, saving you 1 U of rack space.
post #7 of 27 Old 10-25-2011, 07:51 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Brief discussion of front v. rear switch:
http://www.remotecentral.com/cgi-bin...eywords=21501&
You can search for other similar discussions in that forum.
Pakedge and Crestron offer switches with rear-facing ports, but as mentioned in that thread, the rear of the switch may be difficult to access.
I really like Stamp's solution to a forward-facing switch, with the cables coming through the side rack ears. But, I think the rear mounted is much easier.
post #8 of 27 Old 10-25-2011, 07:59 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
For my rack, my original plan was to mount one of the 1/3-depth "utility shelves" to the rear rails, and just set the switch on that - so it wasn't flush with the rear of the rack, and I didn't have to buy a rack-mount switch.
Since I just needed a little 8-port switch (same would work for larger port counts, though), I ended up not even using the shelf - I velcro'ed the switch to the bottom of another shelf. Since my rack pulls out for service, I mounted it sideways, so I can see the lights from one side and the cables are easy to access from the other. The U space consumed was covered with a blank plate anyway...
Jeff
jautor is offline
post #9 of 27 Old 10-25-2011, 06:25 PM
Techphil's Avatar
Techphil is offline
post #10 of 27 Old 10-26-2011, 11:00 AM - Thread Starter
ktrdsl23's Avatar
While your picture is a bit too big for this thread, that MA brush grommet panel does look like a nice way to handle the issue. I didn't realize they sold those. Thanks.
ktrdsl23 is offline
post #11 of 27 Old 10-27-2011, 01:21 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
As soon as I saw the thread title, both Pakedge and a regular switch with the MA brush grommet came to mind. So, +1 for both aforementioned suggestions. I have used both in the field.
cshepard is offline
post #12 of 27 Old 12-23-2012, 11:52 AM
bgarcia's Avatar
Quoted: 45 Post(s)
Liked: 35
Hi,
You can also do this with a HP Pro Curve switch. You can put the mounting ears on the rear of the switch with the ears facing out to the rear rather than the front. I am using a ProCurve 1800-24G for a top of rack switch. Once I have it mounted I will post pictures.
Bryan
bgarcia is offline
post #13 of 27 Old 05-15-2013, 11:06 AM
prnoct90's Avatar
Any other recommendations for this? (looking for 16 port)
prnoct90 is offline
post #14 of 27 Old 05-15-2013, 07:46 PM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
You can mount a small 16 port switch anywhere, with zip ties.
post #15 of 27 Old 05-15-2013, 08:26 PM
AV_Integrated's Avatar
Quoted: 1094 Post(s)
Liked: 794
How about this...
http://www.newegg.com/Product/Product.aspx?Item=N82E16833316165
and then put it onto a standard Middle Atlantic rack shelf which has been cut to fit the switch? It isn't a direct rack mount option, but will give you the clean front face that you can look at to see what connections are live, and the power and network jacks will all be on the back side and accessible to you.
I personally just mounted to my rear rack rails.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #16 of 27 Old 05-16-2013, 05:59 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Netgear GS116
You can find space for that switch anywhere in the rack.
post #17 of 27 Old 10-06-2013, 04:03 PM
Vincent941's Avatar
Try the Tripp lite 32 port B072-032-IP4
All the ports are on the back and you can manage the ports for ip cameras or set up basic use.
Vincent941 is offline
post #18 of 27 Old 10-07-2013, 01:12 PM
M1chael's Avatar
Quoted: 12 Post(s)
FYI....some switches like this one from ZyXEL have the power and ethernet connections on the rear and comes with brackets to attach to a rack. I have this particular one due to its POE capabilities and its seems solid from what I can tell!
http://www.newegg.com/Product/Product.aspx?Item=N82E16833181164
M1chael is offline
post #19 of 27 Old 02-03-2014, 11:51 AM
audiomanNJ's Avatar
I just used this solution from Middle Atlantic. Worked out very nicely. Lets me pick from a large variety of switches on the market, most of which have the RJ-45s and the status lights on the front. As Sofa King pointed out, the aesthetic advantage of having the RJ-45 jacks on the back is countered by the difficulty in getting to those connections due to how shallow the switch is.
While this costs more space in the rack (2U vs. 1U) than 39 Cent Stamp's elegant solution, it requires no drilling or modification and still looks neat.
Middle Atlantic: http://www.middleatlantic.com/rackac/InstallOptions/index.htm
see: RR2-3RCN (recesses the switch 3" from the front of the rack)
http://www.middleatlantic.com/rackac/cablem/cablem.htm
see: BR1 (allows cables to pass through from back of rack neatly)
NJ Audioman
audiomanNJ is offline
post #20 of 27 Old 02-06-2014, 06:36 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 36
Originally Posted by Neurorad View Post
Netgear GS116
I have one of these mounted upside-down to the bottom of one of my rack shelves (which are slotted for ventilation) using small nuts & bolts. The bolts fit through the slots in the shelves and connect to the slots in the bottom of the switch; no drilling was necessary. I have an in-wall rack made by mounting rack rails to a framed opening; I have no rear rack rails with this design. The front of the rack faces into the theater, and the back is in an equipment room where I can go to make cabling and component changes. I have the switch in the equipment room; works well.
Mark
giomania is offline
post #21 of 27 Old 02-08-2014, 07:15 AM
ELECTRICDON's Avatar
This is exactly what you are looking for.
http://www.snapav.com/p-1784-an-100-sw-r-24.aspx
Just find a dealer who will sell to you.
ELECTRICDON is offline
post #22 of 27 Old 02-08-2014, 09:50 AM
txdot's Avatar
http://www.levelfivesystems.com/araknis-networks-100-series-24-port-unmanaged-gigabit-switch-with-rear-ports.html
txdot is offline
post #23 of 27 Old 02-08-2014, 01:12 PM
OUCH, I sell them for half that.
post #24 of 27 Old 02-08-2014, 01:16 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 36
Do you also sell the Snap AV Binary HDBaseT products?
giomania is offline
post #25 of 27 Old 02-10-2014, 04:09 AM
txdot's Avatar
Seriously? If so, where/how do we order?
txdot is offline
post #26 of 27 Old 02-11-2014, 08:55 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Alternative solution:
http://www.amazon.com/1RU-Recessed-Rack-Adapter-Lifetime/dp/B00CMRSQLO
EricN is offline
post #27 of 27 Old 02-11-2014, 11:18 AM
Neurorad's Avatar
Quoted: 227 Post(s)
Liked: 145
Yes, Middle Atlantic's version was linked above.
http://www.amazon.com/Middle-Atlantic-Products-RR2-3RCN/dp/B008CR5SMI
Ships with rack screws and cage nuts (I actually prefer cage nuts to tapped holes).
Reply Home A/V Distribution
