AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Home A/V Distribution (http://www.avsforum.com/forum/36-home-v-distribution/)
-   -   Is ghosting a fault of the cable being used? (http://www.avsforum.com/forum/36-home-v-distribution/1371360-ghosting-fault-cable-being-used.html)
SquirlKiller 11-06-2011 04:55 PM
I bought a component cable for my xbox running xbmc and i noticed some ghosting, is that a fault of the cable? It makes a shadow that is visible and is quite annoying in dark scenes
Colm 11-06-2011 06:18 PM
It can be. It can also be the fault of the electronics at either end of the cable, or a combination.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
