Bluetooth transmitter with optical input? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 85 Old 05-10-2014, 06:47 AM
rsloma's Avatar
Any special trick to get Bose AE2w headphones to pair up with the TosBlue-X transmitter?  I have tried several times with no success.  iPhone doesn't see it nor does my laptop when I have plugged it into my laptop and turned on Bluetooth.  However, both see the headphones.
rsloma is offline
post #62 of 85 Old 05-10-2014, 12:53 PM
rsloma's Avatar
Got it to work.  Had to go somewhere that minimal chance of there being another Bluetooth signal nearby, a nature park not far from the apartment complex where I live.  With my laptop as the input device, both paired up almost immediately.
rsloma is offline
post #63 of 85 Old 05-11-2014, 09:37 AM
Surfer11May's Avatar
Clear previous pairs by holding down the [volume down] and [top button] at the same time until the purple LED lights up on the AE2w headphones. Turn AE2w headphones off then back on. Cycle the power to the TosBlue-X transmitter to start pairing. Press [volume up] and [top button] at the same time until purple LED lights up to make AE2w headphones available for pairing.
Should be able to pair two devices with the AE2w headphones at a time. My cell phone takes priority and the TV comes back in when phone call is not active.
Surfer11May is offline
post #64 of 85 Old 05-21-2014, 02:17 PM
ccll0's Avatar
how much lag is there with the TosBlue-X ?
ccll0 is offline
post #65 of 85 Old 05-24-2014, 11:31 AM
airforce1engine's Avatar
Is it just me?  Am I the only one that is a bit confused??
What would be the purpose of converting such a wonderful audio output source to an analog signal?  I'm unclear why I would want to take a perfectly good 5.1 signal and turn it into stereo?  There are several good 5.1 and even 7.1 Bluetooth headsets that want that pure 5.1 optical signal!
Please...help me understand?
As well, I never read anyone explaining the issue about most TV's having only 1 Optical output, so for most of us with a Surround System already in place that us occupying that SPDIF optical output, where are we supposed to plug in this adapter Transmitter? I was really wondering why not a single post was addressing this.
Just some food for thought....
airforce1engine is offline
post #66 of 85 Old 06-02-2014, 09:58 AM
hakos3d's Avatar
If you have only two speakers (left and right), you can't stream 5.1 audio. 5.1 means 5 different channels over 5 different speakers and 1 channel of a subwoofer signal. It has nothing to do with the clarity or purity of the sound. It's just that each speaker outputs the designated signals to its channel. When you have 2 speakers you can only hear things in stereo, coming from left and/or right speakers.
This adapter does not solve your problem. My TV has the same optical output and I need to take that optical output, connect to a device that accepts optical-in and converts the audio to a bluetooth stream. This bluetooth adapter should be able to stream to at least bluetooth headsets. I only watch movies with my wife after the kids sleep. And I need a good volume to able to enjoy the movie. So, we need:
A bluetooth audio streaming device that accepts optical-in audio and that can be paired with more than 2 bluetooth headsets.
hakos3d is offline
post #67 of 85 Old 07-30-2014, 10:40 AM
Liked: 0
i purchased the TosBlue-X2 it coonects to my speaker but no sound have tried 2 different TosBlue-X2 & 3 different bt speakers still no sound the speakers connects to phones & works find just cant get no sound from tosblue even they see each other i tried it on 60" vizio & 47" lg tried all settings in menue on both tv can anyone help
wildgoose22 is offline
post #68 of 85 Old 09-23-2014, 05:14 PM
Liked: 0
I bought a Tosblue-X2 and found that:
- Tosblue-X2 won't pair by Bluetooth with a Pure Jongo S3 speaker. So I returned the Jongo to the shop and got a Sony.
- Tosblue-X2 will pair by bluetooth with a Sony SRS-X5 speaker.
- Tosblue-X2 will pair by bluetooth with a Canton DM50 soundbase.
The Tosblue, Canton and Sony all have apt-X, whereas the Pure Jongo didn't. Apt-X is a technology for reducing the delay in bluetooth audio transfer, which is important with TV to keep the lips in sync. I don't know if the lack of apt-X is the reason the Jongo wouldn't pair.
My original plan was to stream sound by bluetooth simultaneously to the Canton and the Sony speakers. I thought this would keep the 2 speakers in sync. However, the Tosblue-X2 doesn't seem to be able to stream continuously to 2 speakers at the same time. One of them keeps dropping out for a few moments every few seconds. So instead I connected the Canton directly to the TV with an optical cable and only use the Tosblue to stream bluetooth audio to the Sony.
The delay in audio with the Tosblue/Sony pair is about 30-40 milliseconds, in agreement with what Telme2 claims, but only if I use an optical cable to connect the TV to the Tosblue. With a 3.5 mm audio jack from the headphone socket there is more of a delay. To avoid an echo effect I am using the Canton's built-in delay function at 30 ms, and lips on the TV are reasonably in sync.
So if you want to use Tosblue with a bluetooth speaker for a TV, make sure that the speaker has Apt-X, and use an optical cable to minimise audio lag.
lathyrus is offline
post #69 of 85 Old 10-19-2014, 07:43 AM
Liked: 0
Hi,
I bought the TosBlue-X as an audio bridge between my toslink TV-out and my toslink amp-in, so I don't have to run toslink cable. The corresponding receiver-piece is a QED uPlay plus (with apt-x support and toslink out).
However, I cannot get the 2 devices to pair! Both devices work fine individually (i.e., the TosBlue pairs with my BT-headphones, the uPlay easily pairs with my mobile phone and laptop) but don't pair, even if sitting right next to each other in pairing mode with any other BT-equipment in range.
- Any ideas on what else I could try to get them to pair?
- Has anybody used the TosBlue successfully with a stationary BT-receiver with optical out?
- Are there any better alternatives to build a high-quality audio bridge without breaking the digital chain?
Gerein is offline
post #70 of 85 Old 10-19-2014, 09:04 AM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
Do you have any other wires in place between those two locations that are not in use? Converters can be used to transmit the SPDIF signal over coax or cat5...
jautor is offline
post #71 of 85 Old 11-03-2014, 07:37 AM
libertao's Avatar
Liked: 0
Is there still no cheaper alternative to connect an optical-out TV to a bluetooth headset than the $74 tosblue-x?
libertao is offline
post #72 of 85 Old 11-17-2014, 06:06 PM
ccll0's Avatar
the older version only supported PCM over optical. Does anyone know if this restriction has been eliminated with the new version? For example my tv only has dolby digital via optical.
ccll0 is offline
post #73 of 85 Old 12-02-2014, 10:17 PM
Tech5635's Avatar
Quoted: 16 Post(s)
will the TosBlue X work with a Samsung pn51f8500 using the optical out to pair with the new beats wireless headphones?
Tech5635 is offline
post #74 of 85 Old 12-23-2014, 12:21 PM
Liked: 1
aaa
shamu1023 is offline
post #75 of 85 Old 01-30-2015, 05:56 PM
Liked: 0
Follow-up: I never got the Tosblue to work reliably with my Sony SRS-X5 bluetooth speaker. It often took me 5 minutes or more of repeated attempts to get it to connect to the speaker. It frequently got into a mode where the sound would work for a few seconds, then cut out, then work again. After a few months of frustration I found an alternative product on Amazon.com:
LAYEN® Digital Bluetooth Transmitter - Connect via 3.5mm AUX, Coaxial or Optical Fibre Cable for a Digital Connection
I bought the Layen and it really works, excellent sound quality, problem solved!
lathyrus is offline
post #76 of 85 Old 01-31-2015, 09:27 AM
CyberSteak's Avatar
Quoted: 14 Post(s)
I just received my TosBlue this week. Been trying to get it to connect to my Sony MDR-10RBT headset with no luck. Kind of think it's faulty. Even tried to hook it up to a platonics bluetooth earpiece and got nothing. Both the headset and earpiece work fine and pair up with other devices. Kinda ticked because I had originally bought items from monoprice that would have added the bluetooth tech to my TV but it was a couple of boxes, a couple of cables, and would have needed a power source. And it wasn't going to have aptx tech so there would have been sound delay. I picked up the TosBlue because it was the perfect solution. But honestly I think it either works, or doesn't. The headphones they offered on site were generic headphones that looked quite cheap (I've seen them sold under a different brand). The Sony headset was far better. But alas...I can't get it to work.
I'll have to check in on the Layen one your speaking of. How long have you had it? Does it have aptx tech on it?
CyberSteak is offline
post #77 of 85 Old 02-08-2015, 06:26 PM
scl23enn4m3's Avatar
Can you post a link for this product please? I can't seem to locate it on Amazon.
Edit: found it on Amazon.co.uk though.
Edit2: After some searching it looks like it's a rebranded China product and goes by TS-BTDF01. There are a few companies selling it in the US.
scl23enn4m3 is offline
post #78 of 85 Old 02-17-2015, 07:48 PM
Liked: 0
Cool
I just received my TosBlue X and paired it to my Parrot Zik headphones using the optical cable from a DirecTv optical out. I can't detect any lag whatsoever. The pairing process took a while, I think because a setting in the headphones (ANC disable) needed to be turned off, but once paired, all is good. Right now I'm a very happy camper!
If I encounter any lag in the future, I'll report back...
Gene Krause is offline
post #79 of 85 Old 02-28-2015, 06:48 PM
Liked: 0
Lightbulb
The TS-BTDF01 sells under $40 from some sellers, however it is Bluetooth 2.1. Looks like it can broadcast to up to 10 bluetooth devices at once. Has anyone used this device with the optical output from an LG plasma Dolby HDTV? My TV dates back to 2007, no headphone output. Lag? Sound quality? Seems to be the best-priced optical to bluetooth converter that I have seen so far.
The converter boxes that convert optical/digital to RCA L/R or 3.5 jack and decode Dolby run about $50 on Amazon. The subsequent bluetooth transmitters with 3.5 jack run from about $20 and up.
I am surprised there are not more folks selling devices like this. Bluetooth headphones are all the rage.
oldplasmalg is offline
post #80 of 85 Old 05-09-2015, 03:11 PM
Liked: 0
I found this blue tooth transmitter from DL-Link that has an optical input.
Model: DL-LINK TS-BTAD01
SKU: 261787
Cost: $40 - $55, depending on the seller
Here is a website that is selling the v4.0: dx.com/
Here is a website selling v2.1, and the "questions" section seems to indicate that there is no sound delay from the video: ********.com
I have not been able to find any other manufacturer of a bluetooth transmitter with a fiber optic input.
FYI - Amazon has a BT transmitter with a 3.5mm jack input from AGPtek®: amazon.com
I would have posted the full websites, but this is my first, and likely only, post on this forum.
JustinMT1 is offline
post #81 of 85 Old 05-09-2015, 08:26 PM
Liked: 0
A new bluetooth transmiter with no lag ?
There is a product in Amazon.com very similar with TosBlue-X from Telme2 called "Voxoom wireless TV headphones system". The brand is Voxoom.
Do you know it ?
Wfilho is offline
post #82 of 85 Old 06-29-2015, 10:32 AM
Liked: 0
I used the TosBlue-X for awhile had trouble with it finally ugrade to voxoom got it with bluetooth head set from Amazon for $79.00 very pleased with it had it about 2 weeks
post #83 of 85 Old 09-25-2015, 11:31 PM
les_garten's Avatar
Quoted: 81 Post(s)
They look like the same product?
les_garten is offline
post #84 of 85 Old 09-22-2016, 07:50 PM
ccll0's Avatar
I emailed this company a couple years back, never got a reply. Does anyone know of any alternatives out there besides this company?
ccll0 is offline
post #85 of 85 Old 10-24-2016, 08:46 AM
Liked: 0
Different year, same problem...
Could someone please recommend a good and working BT transmitter with Apt-X, which accepts analog and optical inputs? Or optical only as a worst case.
Michał Kryński is offline
Reply Home A/V Distribution
Displays , Lg 47lh40 47 Inch 1080p 120 Hz Lcd Hdtv Gloss Black , Playstation 3 160gb System , Xbox 360 250gb Console With Kinect
