Best Wireless HDMI Device - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 11-14-2011, 10:39 AM - Thread Starter
geeman2001's Avatar
I'm interested in buying a wireless HDMI system so that I can use my cable box in the basement in my living room. I'll obviously need it to work through walls and the signal will need to transmit at least 30 feet.
Any recommendations?
geeman2001 is offline
post #2 of 47 Old 11-14-2011, 12:07 PM
Colm's Avatar
Liked: 94
First, there is no such thing as wireless HDMI. HDMI is an uncompressed signal. All the wireless systems compress the signal, some more than others. I haven't seen one that will do 30' through walls reliably. 30' line of sight seems to be the limit. Put anything in the way, even a body, and range diminishes.
Colm is offline
post #3 of 47 Old 11-14-2011, 12:09 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Are there no wires to the living room? Is the basement finished, such that running a wire isn't easy?
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #4 of 47 Old 11-14-2011, 12:34 PM
Nitemage's Avatar
Quoted: 50 Post(s)
Liked: 34
You can try the Brite-View Air SyncHD (BV-2322) for around $220. It transmits an uncompressed signal along with the remote control signal. I have one sending 1080p at around 25 ft through a floor. If you can live with 1080i then you can get better range with the unit.
Nitemage is offline
post #5 of 47 Old 11-22-2011, 12:06 AM
hungarianhc's Avatar
This looks great - I need some wireless HDMI for my apartment. Mine will be going about 18 feet, and while it won't be going through any walls, I am planning on mounting it behind the TV. Think it will work alright? I'm guessing it will if you've got it going through a floor!
I did some searching on Amazon, and I found the BV-2322 that you listed.
I also found the BV-1222 for cheaper. Looks like this will do the same job - no?
hungarianhc is offline
post #6 of 47 Old 11-25-2011, 05:04 PM
Ravileao's Avatar
I have been looking in to this as well. Have you looked at the Brite-View BV-2822? That is supposed to be the "new" upgraded version with better transmission and multiple source capability.
Has anybody on the forum used this one?
Ravileao is offline
post #7 of 47 Old 11-26-2011, 01:07 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I have no first hand experience with this product but it might be worth a look > http://www.bestbuy.com/site/Actionte...33&st=wireless
Also available here > http://www.amazon.com/dp/B005L9ZZ32/...SIN=B005L9ZZ32
Vin
Vin is offline
post #8 of 47 Old 11-28-2011, 04:30 PM
ejhuzy's Avatar
Quoted: 17 Post(s)
IOGear has a product that does this too. Anybody try it? It's kind of hard to find somewhere to buy it on line, which makes me nervous.
ioGear Wireless HD Kit
My parents want TV in their bedroom, but there's no way to get wiring into that room without going from outside the house into the 2nd story room. Bummer.
ejhuzy is offline
post #9 of 47 Old 11-28-2011, 04:54 PM
ejhuzy's Avatar
Quoted: 17 Post(s)
The BV-1222 doesn't appear to send IR too. That means you need line of sight to the equipment that is connected to the transmitter.
The Brite-View models do look nice though.
ejhuzy is offline
post #10 of 47 Old 12-01-2011, 10:56 PM
rxman's Avatar
Quoted: 13 Post(s)
i own the actiontec mywirelesstv kit and it works impressively well ~80' one end of house to other thru 4 walls..make sure to update to latest firmware.
running 3D 1080P from directv thru to main set Panasonic VT25 65" then wireless HDMI out to the bedroom to a Vizio 42" 3d M3D421SR. no notable lag and IR emiter/receiver works flawlessly to control output from 3d stb
rxman is offline
post #11 of 47 Old 12-02-2011, 08:28 AM
ejhuzy's Avatar
Quoted: 17 Post(s)
So I guess this technology is called WHDI, here's a link to some products for it. The one that caught my eye was the Belkin, but it won't be available from Amazon until January 1.
Not listed on the web site are the ActionTek, Monoprice, and another one on Amazon that I can't remember.
I really want to get one of these for my parent's situation. The Belkin looks nice because the transmitter can accept 4 HDMI devices.
ejhuzy is offline
post #12 of 47 Old 12-05-2011, 08:16 AM
WHDI is a specific technology. Not all of these (are any of them?) listed use WHDI technology. Has anyone tried gaming on these? I definitely don't want any lag when playing my PS3, but i really don't care if there's a slightly lag w/ video.
post #13 of 47 Old 12-05-2011, 01:30 PM
FlyOnTheWall's Avatar
Quoted: 102 Post(s)
I have one of these as well, and I think it works great. Picture quality is amazing, and it sounds great too. I even have this going through a Rocketfish 4 Port HDMI Switch without any problems. I do feel the IR is a little slow, as this could also be because of the direct TV box. I am having issues updating the firmware, but def feel this is a great value wireless HD/HDMI streamer.
FlyOnTheWall is online now
post #14 of 47 Old 12-07-2011, 08:55 AM
Arcticbear84's Avatar
Kanex Pro makes wireless HDMI transmitter and receiver. I have no experience with them tho
Arcticbear84 is offline
post #15 of 47 Old 12-07-2011, 10:33 AM
ljo000's Avatar
The Vizio one (XWH200 Universal Wireless HD Video and Audio Kit) has some mixed reviews on Amazon with some people saying it works perfectly and others not so much. I think a lot will depend on the specific setup. Make sure with whatever you buy to get it from a store with a good returns policy like Costco.
ljo000 is offline
post #16 of 47 Old 12-08-2011, 11:10 AM
When you say the IR is a bit slow, do you mean changing channels and stuff? Or is there some latency between the transmitter and receiver? I ask because I want to make sure that my PS3 games will work just fine w/ this device!
post #17 of 47 Old 12-08-2011, 11:14 AM
ejhuzy's Avatar
Quoted: 17 Post(s)
Seems like the Vizio product has to be in the same room or at least that's how it reads on Amazon.
ejhuzy is offline
post #18 of 47 Old 12-09-2011, 05:45 PM
Quoted: 102 Post(s)
Yea changing channels feels to be a lil sluggish, but I do think its just becuase of the IR, and the Slower DirectTv box.
Ur PS3 should work fine
post #19 of 47 Old 12-14-2011, 01:59 PM
rxman's Avatar
Quoted: 13 Post(s)
impressed with perfomance, i bought a 2nd kit for another source and set up
can then choose source/destination. ir "slowness" is more due to the way
the ir signal is sent to the directv box (which i detest even in normal use)
than any fault of the mywirelesstv,as the commands are sent sequentially and timed so that the command is properly interpreted on receiver end,ie
to tune hbo channel 501 shows as 5....0....1 the dots representing a short
pause. a lag yes...but it works perfectly with no missing info. happy user
rxman is offline
post #20 of 47 Old 12-15-2011, 06:22 PM
Quoted: 102 Post(s)
Thanks to RXMan for all his help.
Just got the new firmware updated, and this unit is working flawlessly. Picture and sound are in Sync. IR lag was due to direct TV box.
Even works well with an HDMI switcher. Had a few handshake errors in the begining, but all is well now....
post #21 of 47 Old 12-24-2011, 03:11 AM
rxman's Avatar
Quoted: 13 Post(s)
actiontec has posted an upgrade bin file 12/24/11 v1.0.2.40
more bars shown for signal..same results for me....Great! (using multiple units!)
rxman is offline
post #22 of 47 Old 12-24-2011, 02:58 PM
Colm's Avatar
Liked: 94
Sounds like a page out of the Apple iPhone saga...
Colm is offline
post #23 of 47 Old 12-25-2011, 05:33 AM
bluestar48's Avatar
I just hooked this actiontec mywirelesstv kit up and the video works perfectly. It is connected to a sat. receiver via HDMI. The problem I'm having is audio. If I set the sat. receiver to "pass through" the HDMI audio, then no audio to both an A/V receiver and the wireless receiver. If I set the audio to PCM, then both get the audio signal.
Thoughts?
Tony
bluestar48 is offline
post #24 of 47 Old 12-25-2011, 12:33 PM
Thoughts?
Tony
Ya know... count me on in the "video works perfectly, but audio has some issues" camp. My video works great, but the audio seems to have pops, from time to time. It did not do this when it was plugged in directly.
post #25 of 47 Old 12-26-2011, 07:22 AM
Quoted: 102 Post(s)
are you running this in conjunction with an hdmi switcher or an av receiver with hdmi built in?
post #26 of 47 Old 12-26-2011, 11:10 AM
Nope... right now, it's just the TiVo plugged directly into the actiontec.
post #27 of 47 Old 12-30-2011, 03:24 PM
d3mon187's Avatar
Well I certainly wouldn't recommend the new HP wireless TV connect 2. Just went through 2 of them, and neither of them worked with my 360, PC, or AV receiver. Of course HPs support didn't even know what the device was.
Brite-view looks good, but pretty mixed reviews and lots of people complaining of signal drops. Reviews on the Actiontec seem a bit mixed as well, but I think I might try it. Don't care about audio streaming to my projector, and just need uncompressed 1080p/60 low latency video.
Always liked Belkin, so I may wait to see what price that comes out at. Looks like the single source version will be $200. Don't need the multiple input version, but I'd like multiple output. Wanna keep it around the $200 range, which puts the $350 IOgear out.
d3mon187 is offline
post #28 of 47 Old 12-30-2011, 06:01 PM
More thoughts after having used my actiontec for a while now...
- audio issues are gone after firmware update
- NO lag. Like, ZERO lag. I was playing Uncharted on my PS3 last night and loving the fact that it was perfect.
- The IR blaster is handy as a stop-gap solution before going w/ a more robust remote solution. There is a bit of lag w/ the IR blaster.
- This works great w/ my PS3 and my TiVo.
- If there is compression, i'm not noticing it.
post #29 of 47 Old 01-04-2012, 03:42 PM
d3mon187's Avatar
Well I just talked to my sales rep at pcmall, and he said the Belkin currently isn't expected until March. So I guess that makes the Actiontec an obvious choice. Too bad the stupid thing just went up $20 on Amazon. Hopefully its a temporary jump.
d3mon187 is offline
post #30 of 47 Old 02-07-2012, 12:28 PM
ejhuzy's Avatar
Quoted: 17 Post(s)
I bought the 8WD HDMI Transmitter/Receiver kit for my parents for Christmas. I just got around to getting it installed at their house (was waiting for Comcast issues to be solved.
In short, it's working as advertised. It was a snap to set up and it just worked. Here's their set up:
Tivo Premier ->
8WD Transmitter ->
Sony HDTV
8WD Receiver -> Samsung HDTV
The transmitter and receiver are about 15' apart and on different floors of the house.
The Tivo works perfectly on either TV, which means they didn't need a new box to drive the remote TV. The IR solution that comes with the 8WD works fine too, although I sort of wish the receiver had a built in IR receiver (instead of the plug in version it comes with). But it works fine and for some this might be a better solution (if say you want to tuck the receiver out of sight).
One last note, Amazon doesn't seem to have the 8WD anymore. However, they do have the Brite-View which seems like the same exact product.
ejhuzy is offline
Reply Home A/V Distribution
