Need recommendations for impedance matching volume controls that aren't too bulky - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-02-2011, 03:25 PM - Thread Starter
Warblade's Avatar
I had purchased a couple of rotary style impedance matching volume controls from Monoprice but as I was putting them in, the transformers are simply too bulky to fit properly into the gang box I have. The problem is at each volume control area, it is above some kind of light switch. So I've got some electrical work that is just getting in the way of it fitting properly.
The second issue is my wife thinks the rotary style volume controls look ugly. The best I can think of (aside from dropping $1000+ on some kind of integrated system like from Nuvo (preferable) or HTD) is to get a slider type. She seems ok with that. I've looked at many slider type volume controls but I don't want to start ordering items without knowing if they will be bulky. I realize my question is a little vague without providing dimensions but I'm just looking for any recommendations for a slider controls that are good quality, look nice, don't feel "cheap" and aren't bulky.
The speakers that the volume control will be controlling can handle up to 100+ watts but I doubt the receiver will be putting out that much. I'll be hooking up 3 pairs of speakers in parallel (hence the need for the impedance matching controls) to a zone B on a Pioneer VSX-1021-K.
I guess for more background, I had looked into the Lutron Chopin controls. Those actually looked pretty good for what I wanted to do, however you need an entire controller per zone, and I have 3 zones... it just seemed weird the way it worked.
The mid-level system from HTD looked pretty good, but for $1100... it's just too much for me to spend at the moment. Same with the Nuvo Essentia (that would be my dream pick though simply because the controls look pretty slick).
Warblade is offline
post #2 of 9 Old 12-02-2011, 11:49 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
I'm not an expert on this stuff, but I don't believe impedance matching controls allow you to use multiple speakers off one amplifier channel like you are proposing. I think it is one speaker per channel only.
Take a look at the Leviton system matching module and their non-matching volume control sliders.
SG-AMP
SG-VST Volume Control
I've done the exact same setup - used the Zone 2 of a Yamaha receiver to power three pairs of speakers in bedrooms throughout a house. The receiver speaker connections connect to the SG-AMP module, then each volume control connects to each output on the SG-AMP.
sebberry is offline
post #3 of 9 Old 12-03-2011, 05:41 AM
canuck_fr's Avatar
The statement made by sebberry is incorrect.
To my knowledge all impedence matching volume controls are bulky. The non-impedence matching are smaller.
what is you setup? maybe you can use non impedence matching volume controls by adding a multi-channel amp.
canuck_fr is offline
post #4 of 9 Old 12-03-2011, 11:03 AM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
It's ok, I'm learning here too.
So it is OK to daisy chain multiple impedance matching controls on one amp channel and they'll work to maintain a safe impedance?
Would the controls have to be in series or could you run them in parallel too?
I still think if you have the wires from all three rooms it will be cleaner and safer to patch it all in to the Leviton matching module. The controls are a bit smaller too since there is no transformer on them.
sebberry is offline
post #5 of 9 Old 12-03-2011, 11:05 AM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
He wants to run three rooms off the Zone B of the receiver. It would be cheaper to use the Leviton unit to distribute the speaker wires into the various rooms than to add a multi-ch amp.
He'd still have to run impedance matching controls if he had a multi-ch amp, no?
This stuff makes me
sebberry is offline
post #6 of 9 Old 12-03-2011, 01:46 PM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
He's not daisy chaining them, he's running them in parallel, and that is exactly what the impedance-matching device is for - to compensate for multiple pairs in parallel.
True, but the multichannel amp approach allows for upgrades to a multi-source system in the future...
No. With one pair of speakers per channel pair, there's nothing to "match"...
Jeff
jautor is offline
post #7 of 9 Old 12-03-2011, 02:01 PM
sebberry's Avatar
Quoted: 27 Post(s)
Liked: 30
Interesting. The way I always understood it was that if you were adding a volume control, adjusting the volume would alter the impedance of the load. My understanding was that the impedance matching control was to ensure a consistent load regardless of the volume setting.
So what happens to the impedance presented to the amplifier when you use a non-matching volume control? Surely it doesn't stay at 8 ohms, does it?
Another question - if you run two speakers in parallel, the impedance drops by one half. If you add more, the impedance continues to drop. If you have 4 8 ohm speakers for example, the impedance would rop down to 2 ohms, right?
So if impedance matching controls maintain each speaker at the 8ohm load regardless of volume setting, why would having 4 volume controls not cause the system impedance to drop?
sebberry is offline
post #8 of 9 Old 12-03-2011, 05:26 PM
jautor's Avatar
Liked: 832
No, that's not correct. Impedance matching is to "match" the expected impedance at the amplifier - which is an 8 ohm speaker per channel.
See "potentiometer" - it's a voltage divider...
Again, volume isn't the issue - it's the nominal impedance of the load. The "matching" is compensating for the 1/n change when speakers are connected in parallel.
Jeff
jautor is offline
post #9 of 9 Old 12-05-2011, 08:45 AM - Thread Starter
Warblade's Avatar
I ended up getting the SGAMP and the volume controls suggested by sebberry. Hopefully this gets me what I need.
I'll definitely move to a multichannel amp in the future but I need something relatively cheap right away. Thanks for the help guys.
Warblade is offline
Reply Home A/V Distribution
