Split HMDI and bypass receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-08-2012, 10:39 AM - Thread Starter
lassus's Avatar
I need a little help with my setup. Right now my NAD receiver receives HDMI inputs from all of my sources (cable box, Blu-ray, XBox, Apple TV) and is connected to my HDTV with a single HDMI cable (separate cables go to the tower speakers). What I want to do is use my receiver for audio (either the Apple TV or Blu-ray), but simultaneously view a different video source from my cable box or XBox on the HDTV.
I've read that simple unpowered HDMI splitters do not work well. Is a powered matrix splitter what I need to send HDMI signals directly from my cable box and XBox to the HDTV, while being able to use my receiver to listen to another source? Any recommendations appreciated!
Alex
lassus is offline
post #2 of 6 Old 01-08-2012, 01:49 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
So audio from one source, and video from the other, correct?
Well, they're not really 'unpowered', they get power from the HDMI cable. And how well they work is probably more a function of the devices attached and what people are expecting them to do.
If you want to be able to select more than one source (you said Xbox or cable), I'd go with a matrix. If it was just a single source, a splitter would be fine.
Just note, however, that any arrangement that hooks your TV to an HDMI source may cause the source to "downshift" the audio from DD5.1 or better to 2-channel PCM audio. Because the TV doesn't likely support DD5.1.
As an alternative, you could route most or all of your HDMI sources to the TV directly (bypass the receiver), and run digital audio cables from each source to the receiver. Then you'd be able to switch audio/video separately. Only downside currently would be the BD player, as you'll be limited to DD5.1/DTS (no DTS-MA or DD+). If that's an issue, run the BD player only through the receiver, if that meets your usage...
Jeff
jautor is offline
post #3 of 6 Old 01-08-2012, 11:12 PM - Thread Starter
lassus's Avatar
Right, audio from one source, video from another. The "downshifting" of the audio from 5.1 to stereo could be a problem, though: for example, if I'm playing the XBox "normally", with HDMI output going to the receiver, if there happens to be another HDMI connection directly to the TV, then that would likely downgrade the audio signal?
lassus is offline
post #4 of 6 Old 01-08-2012, 11:29 PM
jautor's Avatar
Liked: 778
Yes, once you have the TV (assumed to only have 2-channel audio support) connected to the source device, the source will begin outputting 2-channel audio. It may require a reboot/power cycle of the source to get it "back" to DD5.1...
Jeff
jautor is offline
post #5 of 6 Old 01-10-2012, 02:06 PM - Thread Starter
lassus's Avatar
Thanks for the response. It seems to best approach may be to just run separate composite video cables to the TV and just bypass the whole HDMI mess!
lassus is offline
post #6 of 6 Old 01-10-2012, 02:14 PM
jautor's Avatar
Liked: 778
*component*, not composite, but yes, that's the answer...
jautor is offline
Reply Home A/V Distribution
