3D-capable HDMI over fiber. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-14-2012, 03:29 PM - Thread Starter
majortom's Avatar
I am looking for an inexpensive 3D-capable HDMI (with HDCP) extender that will work over fiber. I would prefer one that has uses fiber with connectors (rather than an integrated fiber HDMI cable). Optional features are: RS-232 and/or IR (bi-directional if possible).
Thanks in advance.
majortom is offline
post #2 of 11 Old 01-14-2012, 03:50 PM
Colm's Avatar
Liked: 94
Gefen and Crestron may have something that will meet your requirements. If fiber isn't an absolute must, HDBaseT products that will do what you want over a single Cat 5e/6 cable are starting to flood the market.
Colm is offline
post #3 of 11 Old 01-14-2012, 04:05 PM
canuck_fr's Avatar
I don't know why you want to go with Fiber, but if this is the only use, HD Base-T is the way to go on a single Cat 6 cable.
canuck_fr is offline
post #4 of 11 Old 01-14-2012, 04:06 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
And "inexpensive" and "fiber" usually aren't spoken together...
jautor is offline
post #5 of 11 Old 01-14-2012, 11:30 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
NeoPro has what you're asking for:
http://www.neoprointegrator.com/docu...ider-B_web.pdf
cshepard is offline
post #6 of 11 Old 01-14-2012, 11:34 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
cshepard is offline
post #7 of 11 Old 01-15-2012, 09:32 AM - Thread Starter
majortom's Avatar
  1. I want to run between buildings in a lighting prone area.
  2. My run is over 150 meters.
  3. I have fiber in place.
majortom is offline
post #8 of 11 Old 01-15-2012, 12:41 PM
jautor's Avatar
Liked: 778
Very timely, I just got a press release from MuxLab about their new HDMI-over-fiber product:
http://www.muxlab.com/assets/files/p...tender_Kit.pdf
Not sure if it's 3D-capable or not, says HDMI v1.3a... Do you really need 3D? Is this for a remote set-top box - if not, that's a long walk to put in a Blu-ray disc...
Jeff
jautor is offline
post #9 of 11 Old 01-17-2012, 10:41 PM
Kei Clark's Avatar
This one will do 3D:
http://www.digitalconnection.com/pro...bles/f6500.asp
It uses LC-Type connectors.
Kei Clark is offline
post #10 of 11 Old 01-17-2014, 12:13 PM
RosinBow's Avatar
Quoted: 27 Post(s)
Link to my recent experience with this in another thread...
http://www.avsforum.com/t/1453842/hdmi-over-fiber#post_24226205
RosinBow is offline
post #11 of 11 Old 01-21-2014, 09:54 PM
ceat's Avatar
the installed fiber optic cable may not support the extenders, it will be expensive... good luck
ceat is offline
Reply Home A/V Distribution
