Digicon & Belden - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-03-2012, 03:15 PM - Thread Starter
tjk3030's Avatar
Quoted: 53 Post(s)
Does anyone know where I can find out which digicon compression fitting, either green or blue is the best match for Belden 7915a coax?
This ain't no party, this ain't no disco
tjk3030 is offline
post #2 of 7 Old 02-03-2012, 03:54 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Got Google? http://www.arrisistore.com/digicon/D...tion-Guide.pdf and http://www.belden.com/techdatas/english/7915A.pdf. Blue.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 7 Old 02-03-2012, 03:54 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
7915a is a tri-shield cable. You're gonna have to use the green ones. Blue is for dual-shield only.
CIAO!
Ed N.
egnlsn is offline
post #4 of 7 Old 02-03-2012, 04:02 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Not according to Arris: http://www.arrisistore.com/product.php?pid=708860
although the green ones will work too: http://www.arrisistore.com/product.php?pid=708861
olyteddy is offline
post #5 of 7 Old 02-03-2012, 05:06 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Thanks! I always thought they were dual only. Maybe they changed them the same time they changed the green to universal.
CIAO!
Ed N.
egnlsn is offline
post #6 of 7 Old 02-03-2012, 05:23 PM - Thread Starter
tjk3030's Avatar
Quoted: 53 Post(s)
I had picked up 2 bags of digicon blue & green at a yard sale for $3. Tried both on the Belden cable, they both worked. So was wondering which ones were preferable to use.
tjk3030 is offline
post #7 of 7 Old 02-03-2012, 05:30 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
The blue ones are for dual and tri-shield cable, while the green ones are for tri and quad-shield cable. So, for tri-shield cable, you can use either.
CIAO!
Ed N.
egnlsn is offline
Reply Home A/V Distribution
