Nyrius NAVS500 HD 1080p - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-06-2012, 10:28 PM - Thread Starter
RobBanton's Avatar
Does anyone have a thoughts on this product? I want to move all of my equipment into a closet with just one HDMI cable going into the TV. I have a receiver that will output my PS3, Xbox 360 and cable from only one HDMI output and thought this would work. I just want to get some heads up or input on the product before I buy it. Amazon has decent reviews but any other opinions would be great.
http://nyrius.com/products/display.php?id=114&i=1
RobBanton is offline
post #2 of 11 Old 03-17-2012, 03:11 PM
alb2's Avatar
Planning to get that when i pull the trigger on one of assassin htpc
Want to know how it handle block walls. still waiting on reply from nyrius.
I know it have usb port for firmware upgrades which is cool.If it don't
work out the way you want it you can always return it to amazon .
alb2 is offline
post #3 of 11 Old 03-20-2012, 10:47 AM
alb2's Avatar
They told me it works by LINE OF SIGHT only.Yet they advertise it can go
through floors,walls etc.
alb2 is offline
post #4 of 11 Old 03-20-2012, 08:20 PM - Thread Starter
RobBanton's Avatar
Thanks for the heads up man. I wish it worked thru walls. I was ready to pull the trigger too. Keep me updated if you decide to get it or not.
post #5 of 11 Old 03-22-2012, 10:28 AM
Bluehawk248's Avatar
I was looking up info on the NAVS500 and I was told that it will work through walls. A friend of mine already has it and they use it with walls inbetween. When I asked them about it they said that it works no problem when its going through a few walls. Apparently it works best with direct line of sight but it can go through walls. I'm not sure how many walls before it starts having an issue but when I get mine I'll test it. Looking forward to a cleaner TV setup.
Bluehawk248 is offline
post #6 of 11 Old 09-09-2012, 08:51 AM
sloggy420's Avatar
I have it and it works through walls for me. Its actually a really col device since the remote extender is included. Sometimes I have to reset the device b/c the picture goes a little wierd but it is a clean setup
sloggy420 is offline
post #7 of 11 Old 09-09-2012, 10:18 AM
rnrgagne's Avatar
Quoted: 49 Post(s)
Liked: 56
I just bought the Iogear 3D HD unit because my in-wall HDMI cable crapped out. http://www.iogear.com/product/GW3DHDKIT/
I do have line of sight about 15' from my PJ and it works perfectly. Slick device, it handles Blu Ray 1080p/24 with no issue at all and supposedly it can handle up to 100' through walls etc, but that's probably not an automatic. It does have an IR blaster which would come in handy for remote gear.
Probably want to make sure that you can return whatever you buy in case it doesn't work in your application. The other option that's out there is HDMI over cat5e, if you end up having to go wired it's a cheaper easier to retrofit than HDMI.
rnrgagne is offline
post #8 of 11 Old 09-10-2012, 09:49 PM - Thread Starter
RobBanton's Avatar
I still haven't bought the thing but from some of the comments it sounds like a viable option than having to run cables. Thanks again for everyones input.
post #9 of 11 Old 10-02-2012, 08:56 PM
Randall.White's Avatar
Quoted: 353 Post(s)
Liked: 89
Anyone figure out how many walls this will work through?
What I'd like to do is hook this up to my Onkyo reciever in my living room and have it play in my game room. Direct line would be 50' or so and through 2 walls. Do they need to be facing each other or does it send a signal out in all directions?
Anyone have anything similar? Planning on using this for UFC, Football, other sporting events. Just cheaper (in the long run) than buying another HD box from DirecTV.
Randall.White is offline
post #10 of 11 Old 10-23-2012, 02:09 PM
dcottle's Avatar
I would want to use this with a projector mounted on the ceiling.
Does anyone know if there is a way to mount this on the ceiling next to the projector?
Also, does the device transmit full 1080p, or is it compressed in some way? If the signal is compressed, are any compression artifacts noticeable?
dcottle is offline
post #11 of 11 Old 01-12-2013, 05:34 PM
bnewt's Avatar
Quoted: 55 Post(s)
interested in this devise as well as the HD Flow & IOgear32HDkit
do they all transmit 3d & dolby surrond. I want to connect to my tv upstairs
May God Guide and Guard the USA!
bnewt is offline
Reply Home A/V Distribution
