In-Wall IR Sensor - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2012, 07:18 PM - Thread Starter
wiz561's Avatar
Quoted: 16 Post(s)
Hi!
I am installing a Xantech ML85K, which has the peephole style IR receiver. I mounted the receiver in the in-wall speaker, and the 3.5mm wire runs about three feet down into the basement. It then gets an extension cable and runs over to the av receiver and other equipment.
I was wondering if this xantech ir receiver wire is 'in-wall' approved. I know the receiver has a LED in it that blinks when you send a remote code, so it makes me think there's some sort of power going through it. I then was wondering if it's alright to run it in the wall by itself.
wiz561 is offline
post #2 of 3 Old 02-09-2012, 07:45 PM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
Probably not, but I wouldn't be too concerned about it...
jautor is offline
post #3 of 3 Old 02-10-2012, 06:45 AM - Thread Starter
wiz561's Avatar
Quoted: 16 Post(s)
wiz561 is offline
Reply Home A/V Distribution
