3D compliancy test fails with splitter. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2012, 04:43 PM - Thread Starter
Audiophill's Avatar
I have a 3D TV and a 2D TV connected to my AV Receiver via a 3D compliant splitter. When I load 3D media (DVD) the disc initiates a test and determines that my system is not 3D compliant because it sees the 2D TV. I have not been able to locate a splitter that somehow masks or spoofs the test into not seeing the 2D TV. The only solution I can find would be a 4X2 Matrix switcher that would switch the 3D TV in and out of it's internal switcher. Does anyone have a more elegant solution and less costly solution? Assume HDMI.
Audiophill is offline
post #2 of 3 Old 02-21-2012, 04:50 PM
jautor's Avatar
Quoted: 1241 Post(s)
Liked: 798
It's working just as it was designed to... Best chance would be an HDMI Detective from Gefen - not sure if it's got the 3D support or not (good question for Gefen).
Jeff
jautor is offline
post #3 of 3 Old 03-12-2012, 09:17 AM
Arcticbear84's Avatar
This will do the trick.
Octava 1x2 HDMI splitter
Connect your DVD player to the Octava 1x2 HDMI splitter then have 2 outputs go to 2 TV.
The Octava 1x2 HDMI splitter will tell DVD player to play 3D whenever possible.
Arcticbear84 is offline
Reply Home A/V Distribution
