4x2 HDMI Matrix Switch with spdif switching (for Older Receivers) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-05-2012, 04:59 PM - Thread Starter
jerndl's Avatar
Quoted: 31 Post(s)
I have 2 older receivers that do not have HDMI inputs and I am considering a HDMI 4x2 matrix switch. I am currently using a 4x2 component switch that also switches digital audio. Are there any HDMI switches that also switch digital audio (coax or optical)? I have found many but they only have one spdif output, but I need two. What good is only one spdif output? Am I missing something here? Thanks.
Jay
jerndl is offline
post #2 of 6 Old 03-05-2012, 05:20 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
Why do you want to move to an HDMI matrix if you don't have any gear that supports it? You're not likely to see any improvement in image quality at the display(s), and you're already limited to the audio capabilities of SPDIF...
The single digital audio output is probably to handle "one legacy device". Meaning, if you've got a bunch of legacy devices, you probably aren't using the product.
If you have one primary display and are concerned with getting "the best possible image" from a BD player, just run one HDMI cable directly (bypass the matrix), and keep everything else the same.
Jeff
jautor is offline
post #3 of 6 Old 03-05-2012, 06:07 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
If you're set on 4x2 HDMI distribution, just keep using your component matrix for the audio side. HDMI matrices w/ no separate audio are much more abundant.
cshepard is offline
post #4 of 6 Old 03-05-2012, 07:33 PM - Thread Starter
jerndl's Avatar
Quoted: 31 Post(s)
All my source components have HDMI (and most new ones are going to HDMI only) and my 2 TVs have HDMI. It's only my 2 AV receivers that don't have HDMI. It just seems weird to me that the HDMI matrix switches only have one spdif out. I was hoping to simplify my wiring with the HDMI switch but it doesn't look like I'll be able to unless I get a new receiver.
Jay
jerndl is offline
post #5 of 6 Old 03-06-2012, 06:53 PM
editor363's Avatar
best result would come from using a 4x2 hdmi matrix and two of these:
http://www.google.com/products/catal...wAw#scoring=tp
editor363 is offline
post #6 of 6 Old 03-06-2012, 08:32 PM
jautor's Avatar
Liked: 778
That's a very interesting idea for a solution. Let the HDMI sources dumb down to 2-ch, but keep the DD/DTS audio support for any receivers in the mix...
(not as good as leaving it alone, but yeah, I like it )
Jeff
jautor is offline
Reply Home A/V Distribution
