HDMI 3D audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-13-2012, 01:31 PM - Thread Starter
Arcticbear84's Avatar
Not sure if this is the right place for the question. So I apologize in advance if it's in the wrong place.
I have a friend that has a Sony 3D TV, and a Sony 3D Blu-Ray player.
but he's Yamaha receiver does not support 3D.
Is there a box that has 1 input and 2 outputs.
1 output goes to TV for video
1 output goes to Yamaha for HD audio
If not, can anyone recommend a dual output DVD player, we couldn't find any at our local Best Buy
Arcticbear84 is offline
post #2 of 8 Old 03-13-2012, 02:29 PM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
Simplest answer is to run HDMI directly to the TV, and a separate digital audio cable to the receiver. Only downside is if the receiver has support for DTS-MA, you wouldn't get that (only DTS or DD5.1).
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 8 Old 03-14-2012, 07:45 AM - Thread Starter
thanks jautor for the quick response.
Your solution is what we are running right now. But he wants to have the HD audio ability back. He said he can tell the difference between DTS5.1 and DTS-Master Audio (I can't, to be honest).
post #4 of 8 Old 03-14-2012, 08:51 AM
jautor's Avatar
Liked: 852
Ok, then the next answer is an HDMI splitter and a Gefen HDMI Detective to fool the BD player into thinking both components are 3D-capable.
Or sell the Yamaha and buy a 3D-capable receiver, which may not cost much more and he'd probably get some new features (Pandora? Spotify?) and better results...
Jeff
jautor is offline
post #5 of 8 Old 03-14-2012, 10:36 AM
dharel's Avatar
Liked: 33
If your friend is willing to spend the money, an OPPO 93 will do what you want as it has dual HDMI outputs. HDMI1 to TV and HDMI2 to receiver.
dharel is offline
post #6 of 8 Old 03-14-2012, 10:55 AM - Thread Starter
We just tried it with Atlona 1x2 unit.
The TV has 3D with Dolby Digital 5.1 fine, but Yamaha is flashing PCM 2-channel with no sound.
We probably gonna search for a dual output DVD player or another receiver depends on which one is cheaper.
Thanks for the help!
post #7 of 8 Old 03-19-2012, 07:14 PM
jeffro23's Avatar
Ill use this topic to ask a related question, though much less tech savvy
seems like a common problem.... got a new LG 3D TV, My pioneer Elite VSX-01TXH doesnt support 3D.
I really dont want to drop another grand on a new receiver and the audio from the Elite is superb. (unless theres a receommended replacement suggestion???)
So... do I run the HDMI from the source players (PS3/DirecTV HR24) to the TV(LG 55LM7600) and then optical audio back to the Pioneer receiver?
or...
run the HDMI video only from the source players to the TV and the audio seperately to the Pioneer?
2nd one would require 2 seperate switching but My Harmony remote should be able to handle it.
Just wanted to see which would produce the best audio (if noticeable difference)
thanks
jeffro23 is offline
post #8 of 8 Old 03-19-2012, 07:27 PM
jautor's Avatar
Liked: 852
No difference since DirecTV is only sending DD anyway... Check if your TV will output digital audio from HDMI sources, but you may still have better luck with the separate cable anyway...
Jeff
jautor is offline
Reply Home A/V Distribution
