Whole House Audio opinion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-15-2012, 06:51 AM - Thread Starter
adamfit's Avatar
This kind of a newbie question, one for parents.
I'm doing a WHA setup for new construction with equipment from HTD, and I'm trying to decide if I should install in my kids rooms.
I can do the whole house comfortably, 6 zones, each with an Aux jack for MP3 play or intercom, nice system. But we have not included the kids rooms. that will cost money I don't have right now. I can prewire, no problem there, and install later....but do kids really need it?
My friend in the industry says they typically ignore kids rooms, he says kids tend to have a boom box or something.
Ultimately, it comes down to what one wants, I know...just curious to the general consensus.
adamfit is offline
post #2 of 7 Old 03-15-2012, 07:59 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
I think you answered your own question. Absolutely do the pre-wire. Then, later, if the kids say "I wish I had that in my room", you're set for a simple job...
And "need" is a strong word for audio in most any zone.
Jeff
jautor is offline
post #3 of 7 Old 03-15-2012, 08:38 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
My 8 year old has said that he wants a zone in his room. I'd like to have control over what he listens to - but whether it's the whole-house audio system (Nuvo) or an iTouch (or other music player), I don't think I'll have much control either way. For the time being, I'll hold off, but it would be very easy to add speakers and KPs to my kids' rooms (attic above).
How easy would it be to retrofit cables later? It will probably cost you a few hundred dollars to prewire a couple rooms for distributed audio.
You may want to consider wiring their windows with alarm contacts, depending on how easy it is to 'sneak out'.
Ron_
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #4 of 7 Old 03-15-2012, 09:47 AM
jautor's Avatar
Liked: 777
Good caveat - if it will be easy to do later, you can skip the pre-wire. I didn't wire my spare bedrooms because I could get to it. But I've now wired them, and it took a lot longer than I expected. In hindsight, I would have pre-wired it (assuming $100/room).
If you're wiring it yourself, then yes, absolutely do it...
Jeff
jautor is offline
post #5 of 7 Old 03-15-2012, 09:16 PM
dankuz's Avatar
I think (depending on your system) if you put the master controls maybe in the master bedroom and then had independent volume controls in each bedroom that wouldn't be a bad idea. With the HTD system for example you run all cat5s to the keypads in the master and the the speaker wire runs to the zones through independent volume controls. This way the kids have it, but you have full control.
dankuz is offline
post #6 of 7 Old 03-15-2012, 09:45 PM - Thread Starter
adamfit's Avatar
Jeff
QED.
thats the answer.
adamfit is offline
post #7 of 7 Old 03-15-2012, 09:46 PM - Thread Starter
adamfit's Avatar
Excelent advice all around.
Thank you all.
adamfit is offline
Reply Home A/V Distribution
