help needed to hide all equipments - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-16-2012, 09:48 PM - Thread Starter
nomi640's Avatar
Hi guys,
I am planning to hide all my equipments and move them in the basement here are the details of equipments
1- HDMI cable box
2- HDMI DVD
3- Composite dish set box
4- Media center PC
I just have coax and Ethernet connection available from my basement, and I would like to connect two TVs with these equipment, I need advise to buy A/V switch which can be connected through Ethernet and IR repeater to control over coax all these equipments from two rooms
I would really appreciate you guys if you can help me to chose the right equipment to do this setup.
nomi640 is offline
post #2 of 15 Old 03-17-2012, 12:13 AM - Thread Starter
nomi640's Avatar
Any thougths?
nomi640 is offline
post #3 of 15 Old 03-17-2012, 02:14 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
Exactly what wire(s) do you have from the basement to each of the TV locations? Can you run more wire between them?
If the house wasn't wired for distributing video, your choices to do this without running more wire will be limited and relatively expensive.
You can do some reading around here, look for "HDMI matrix switch" and "HDMI over cat5" regarding distribution. IR remote repeating is built into a lot of these products, and if not, can be handled separately, or can be avoided by using RF remotes instead.
Jeff
jautor is online now
post #4 of 15 Old 03-17-2012, 02:37 PM - Thread Starter
nomi640's Avatar
I do have cat5/ethernate and coax wiring from basement and I don't have any choice to run more wires I am looking to have HDMI matrix switch which can handle HDMI, component and VGA.
Could you please suggest good matrix switch and RF solution which work easily
Jeff
nomi640 is offline
post #5 of 15 Old 03-17-2012, 03:27 PM - Thread Starter
nomi640's Avatar
http://www.allaboutadapters.com/hdmuavcewico.html
Any thoughts for this product?
nomi640 is offline
post #6 of 15 Old 03-17-2012, 04:16 PM
jautor's Avatar
Liked: 778
You have individual Cat5e/coax runs from the basement to each TV location you want to use?
You need to get your sources to a common video type (HDMI or component), then look for an appropriate matrix. If your cable box and DVD player have component video outputs, that will be much, much easier and simpler to implement.
Jeff
post #7 of 15 Old 03-17-2012, 04:19 PM
jautor's Avatar
Liked: 778
Many PC video adapter can do component instead of VGA, otherwise that product is easily replaced by any modern AV receiver. But neither of those get you two outputs (for both TVs).
Unless you're ok with the same thing showing on both TVs at the same time? If so, this would work...
Jeff
post #8 of 15 Old 03-17-2012, 06:09 PM - Thread Starter
nomi640's Avatar
Yes I have Cat5e /Coax at both locations
Jeff
I have 2 HDMI, one VGA and one composite (non HD) and I don't mind to watch same thing on both TVs becuase we using one at a time.
really appriciate your help.
nomi640 is offline
post #9 of 15 Old 03-17-2012, 08:13 PM
jmaxbrod's Avatar
You'll have a very hard time with this, try to like Jeff said, get one video protocol ie hdmi, component etc. I would use 4 Zeevee boxes converted to rg6 for your sources and then you can choose what you wanna watch on how many tv's you want by tuning them to different channels. Then run ip control system like RTI or something similar. This way you can add tv's or move them or whatever. It's reliable and easy to use. And along the same cost line once you buy 20 different items to make this and that work.
jmaxbrod is offline
post #10 of 15 Old 03-18-2012, 11:26 AM - Thread Starter
nomi640's Avatar
If I connect just one TV what is a cheapest option?
nomi640 is offline
post #11 of 15 Old 03-18-2012, 01:54 PM
jmaxbrod's Avatar
Using an av receiver that will handle all your source equipment
jmaxbrod is offline
post #12 of 15 Old 03-18-2012, 08:24 PM - Thread Starter
nomi640's Avatar
Any suggestions?
nomi640 is offline
post #13 of 15 Old 03-18-2012, 09:41 PM
jmaxbrod's Avatar
Any suggestions?
You can look at reviews and see which ones have the inputs you need. I can't recommend one for what you need, because I don't recommend doing it that way.
jmaxbrod is offline
post #14 of 15 Old 03-21-2012, 03:32 PM - Thread Starter
nomi640's Avatar
I am still struggling to find out what kind of AV receiver should I review, should be AV receivers or the switches,
I was wondering are AV receiver such as Pioneer VSX 821-K AV receiver can serve the purpose or do I need to look different equipment for this?
I am thinking to have AV receiver plug in to HDMI to Cat5e adaptor to connect the TV on other end?
nomi640 is offline
post #15 of 15 Old 03-23-2012, 09:26 PM
scl23enn4m3's Avatar
That receiver will work. And I think it can be had new for ~$170 now a days. I don't think it has a VGA input though. Maybe you can upgrade your video card to one with an HDMI out? If you stick with VGA, you still have to worry about the audio part.
Connect a HDMI baluns to each end of your Cat5. Plug it into the receivers HDMI output, and your TV.
If feeling risky, you can add an HDMI splitter to your receiver's HDMI out, and then split the signal to both of your TVs assuming you have HDMI baluns for both.
scl23enn4m3 is offline
Reply Home A/V Distribution
