Multiple TV's Multiple Sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-17-2012, 06:33 AM - Thread Starter
bozsta's Avatar
Hi,
I have 4 Tv's that are in 1 room. I am trying to find a solution whereby I can listen to the TV's by plugging a headphone into something that will allow me to change the channel (audio only) and obviously volume up or down BUT only on the individual unit where the headphone is plugged in.
I hope im explaining this correctly, you see a similar set up in many fitness centres where they have tv's on the wall and when a user uses a treadmill or bike they can plug their headphones into a little box that only has channel up and down, you cant change the actual tv channel but you change the channel you are listening to....is this a radio frequency set up? If anyone can direct me to the hardware that I require please help as I need this quite urgently.
Thanks in advance
bozsta is offline
post #2 of 3 Old 03-17-2012, 10:55 AM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 920
A common way to do that is by using 4 FM transmitters so you can change the channel by selecting a different transmission on your FM receiver.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 3 Old 03-17-2012, 06:03 PM - Thread Starter
bozsta's Avatar
thanks for that,
would you know any specific brand that I could look for that allows for multiple audio inputs and selection of fm frequency?
bozsta is offline
Reply Home A/V Distribution
