A-Bus Audio Distribution ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2012, 09:09 AM - Thread Starter
PakZX3's Avatar
So my Dad has an A-bus audio disribution set up. It uses line input for audio distribution.
What should the input to the a-bus system be? Line out from the receiver? What output is that? Can you use the subwoofer output? I think you need a non-amplified source so a speaker output is not acceptable, or is it?
Maybe I am missing something in all of my searching online for some additional info for the input source. We are planning on getting a new receiver and tv (his went kaput last week), but I wanted to get a handle on how to feed the home audio distribution from a newer receiver.
Any help would be greatly appreciated.
PakZX3 is offline
post #2 of 3 Old 03-19-2012, 09:49 AM
jautor's Avatar
Quoted: 1217 Post(s)
Liked: 780
Needs to be a fixed, line-level (non-amplified) output - really should be a "source", but a pre-amp output from an A/V receiver can work. If the receiver has a "tape loop record out", that can work, too.
Definitely not a speaker or subwoofer output.
Unless you're planning to use multiple sources (Radio, CD player, etc.), just plug the source component into the A-Bus directly. And that's only an issue if your A-Bus hub only accepts one input. If it supports multiple, run each source directly, using a Y-cable/splitter if needed.
Jeff
jautor is offline
post #3 of 3 Old 03-19-2012, 11:47 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Look for a 'networked' AV receiver, so you can listen to Pandora and internet radio. Onkyo seems to be a popular brand.
Read the AVR manual before buying.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
