Muti-room Audio Config. Will This Work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-19-2012, 09:01 AM - Thread Starter
joeyg2391's Avatar
Hello guys,
Was wondering if you could help me out. Can my setup work or do i need impedence match volume control knobs. When would i need to get that type of volume controls? all of this would be controlled by my receiver's zone two outputs going into my amps and then being distributed to 6 rooms. I really appreciate your feedback.
equipment
http://www.platt.com/CutSheets/Levit...VSGVSTW_MW.pdf
http://www.parts-express.com/pedocs/...240-manual.pdf
http://www.amazon.com/Polk-Audio-In-...2172893&sr=8-1
joeyg2391 is offline
post #2 of 3 Old 03-19-2012, 04:24 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
No need for inpedance vc's. But in my experience, the sliders stop working far before the rotary ones do. It's all about contact and the rotary ones just last longer.
Your config looks fine. But you might want to look at a pair of speakers in rooms that would benefit them instead of using a single stereo speaker.
ifor is offline
post #3 of 3 Old 03-20-2012, 06:36 AM - Thread Starter
joeyg2391's Avatar
thanks for the confirmation. I was going to go for the dual speaker setup but my GF was'nt liking all the holes in the ceiling so i went that route. When would i need the impedence matching VC's? Again appreciate the feedback
Reply Home A/V Distribution
