Problem displaying metadata on Russound MDK-C5 keypad - AVS Forum | Home Theater Discussions And Reviews
Old 03-19-2012, 04:10 PM - Thread Starter
Smallwonder1's Avatar
Hello everyone
I have an 8 zone MCA-C5 s/w rev 05.01.01, with 6 MDK-C5 s/w rev 05.00.05. I have an iBridge kit (Dock BGD1, Decoder RAVD1) connected to source 2. It is connected correctly and music does play from the iPod. The problem is as follows; while I can select the iPod from the keypad home menu and the music plays, I do not have any metadata. I can move from track to track, but I cannot select a different album or music selection from the iPod. I also don't have any access to the "menu" on the keypad. I don't get the menu option back until i power down the iBridge. Does anyone have any ideas what might be the problem ?
Also, can I use any iPod with the Dock. Should I be able to use my iPhone with the Dock?
Thanks in advance of any help anyone can give.
Smallwonder1 is offline
Old 03-20-2012, 07:36 AM
Eric G's Avatar
There is no firmware version 5.01.01 for the MCA-C5. Check it again. What rev iBridge dock do you have? Flip it over. Does it say rev 1?
Eric G is offline
Old 03-20-2012, 10:48 AM - Thread Starter
Thanks Greg for your reply
I am not at my home at the moment to check the system for what you have indicated.
I will not be there until Thursday. I will get back with that info then.
Old 03-20-2012, 10:49 AM - Thread Starter
Apologies I shuold have said thanks Eric G instead of Greg in my last post
Old 03-27-2012, 11:14 AM - Thread Starter
I checked the s/w from the Keypad MDK-C5 (should I have checked this using the SCS-C5 ) ?
The s/w revisions are as follows
MCA-C5 is 04.01.01
MDK-C5 is 05.00.05
Boot is 01.00.05
The iPod doc s/w is REV2 2.03.01.
Is this helpful.
Am I correct to assume that I should be able to dock my iPhone 4 s/w 5.1 and control my music from the the MDK-C5 ?
As I said in my original post I have tried an ipod and my iphone and I get a similar problem (see original post for description of problem)
Old 03-28-2012, 02:49 PM
Eric G's Avatar
The iPhone has never been a supported device with the iBridge dock. That said, make sure the dial on the back of the dock is actually set to the correct source number. If it's in source 2 of the C5, make sure the little black arrow is pointed to the 2. If it's not, change it and power cycle the dock.
Eric G is offline
