Speaker Selector with Remote control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-20-2012, 07:00 PM - Thread Starter
zhangyeus's Avatar
Is it just me or there is no decent speaker selector with remote RS232 control? I have Sonos and a Sonamp 275. I want to use it as the only source to drive 10 zones in my house. Each zone is a single mono speaker.
I am trying to find a mono speaker selector with remote control. All I get is this
http://home.earthlink.net/~ohiojason/Speaker/10way.htm
No remote control, and the minimum ohm is 2. So it is not what I am looking for.
Then I figure that it is OK to reduce it to 6-7 zones, as long as there is a speaker selector with remote control. So I found these two:
http://www.outdoorspeakerdepot.com/7...e-control.html
and
http://www.atonhome.com/DLA6Room.html
Both of them have IR control options and the first one is much more expensive and nicer.
Can someone help me understand if there is other options?
Thanks a lot.
zhangyeus is offline
post #2 of 4 Old 03-20-2012, 07:08 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
There aren't a lot of choices because most folks would recommend going with a multichannel amp or whole-house audio system when talking about that many zones...
I think you found the obvious choices.
Jeff
jautor is offline
post #3 of 4 Old 03-20-2012, 08:09 PM - Thread Starter
zhangyeus's Avatar
Jeff
Tanks. I will go with the ATM-7 then
post #4 of 4 Old 03-20-2012, 09:41 PM
Doug Balentine's Avatar
Been using ATM-7 for a year. Real happy with it.
Doug Balentine is offline
Reply Home A/V Distribution
