Cat5e to RCA connector (non-keystone)?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-23-2012, 08:47 AM - Thread Starter
ljo000's Avatar
Does anyone know of any Cat5e to RCA connectors that are not keystone jacks? Something like the leviton ones but for a stand-alone cable. I'm trying to connect my sub-woofer with an existing cat5e run to a Monoprice 5.1 wall plate. The sub connector on the wall plate is just a regular RCA jack. Thanks!
Edit: Just to be clear I'm looking for a Cat5e to male RCA. Something like this - Coax to RCA - except for category cable.
ljo000 is offline
post #2 of 7 Old 03-23-2012, 09:46 AM
jautor's Avatar
Quoted: 1331 Post(s)
Liked: 852
http://www.muxlab.com/products/ve_av...og_balun.html#
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is online now
post #3 of 7 Old 03-23-2012, 09:49 AM - Thread Starter
ljo000's Avatar
Damn thats perfect but expensive. Its a 30' run so I may just have to run a coax cable instead. Snaking wire is a pain...
ljo000 is offline
post #4 of 7 Old 03-23-2012, 11:06 AM
jautor's Avatar
Liked: 852
Any cheaper than that wouldn't be a balun, just a connector. Which of course you could try first and see if you get acceptable results. Just take an RCA connector (or a cable), and splice/solder the connector onto the cat5. Twist 4 conductors together to get a thicker wire...
Jeff
post #5 of 7 Old 03-24-2012, 02:29 AM
Phillip@4lee's Avatar
Take a passive cat-5 to bnc Balun and add a bnc to RCA adapter. Total cost will be between 25 and 45 depending on your source.
Phillip@4lee is offline
post #6 of 7 Old 03-24-2012, 06:41 AM
alexsquared's Avatar
Why not use a cat5 to RCA keystone jack and just put the jack in the wall. Use a small male-male rca patch cable from the keystone to back of the Monoprice.
alexsquared is offline
post #7 of 7 Old 03-24-2012, 04:49 PM - Thread Starter
ljo000's Avatar
Thats what I did in the end - cat5e -> leviton ->patch cable -> wall plate. I was hoping there was just a small adapter but this solution worked fine. Thanks for the suggestions all.
ljo000 is offline
Reply Home A/V Distribution
