15ft Component cable VS Component to HDMI converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-28-2012, 07:40 PM - Thread Starter
SquirlKiller's Avatar
I am in a bit of a dilemma. I have an xbox that i have XBMC on and need to feed it to my TV which is about 11-12ft away and want to have the very lowest ghosting possible. Should i use a well shielded 15ft component cable or just use an extremely short component cable and connect to a HDMI converter?
SquirlKiller is offline
post #2 of 6 Old 03-28-2012, 08:40 PM
rgiron's Avatar
why not just run an hdmi cable?
Ronnie, CT,DMC-E
Crestron Programmer/Designer
Owner www.audiovideoarchitech.com
rgiron is offline
post #3 of 6 Old 03-29-2012, 07:30 PM - Thread Starter
its an xbox 1, it doesn't have HDMI on it
post #4 of 6 Old 03-29-2012, 10:08 PM
KingLeerUK's Avatar
Liked: 75
At 15' just about any component cable will do just fine and you'll avoid any potential format conversion or HDMI handshaking issues that might be introduced by a convertor.
KingLeerUK is offline
post #5 of 6 Old 03-30-2012, 09:58 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
I have a 50' component video cable from Monoprice that works like a champ!
NickTheGreat is offline
post #6 of 6 Old 03-31-2012, 07:38 PM - Thread Starter
guess i'll go with component, thanks guys
Reply Home A/V Distribution
