HDMI over RG6 converters - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-02-2012, 10:06 AM - Thread Starter
bradg33's Avatar
Has anyone actually used one? I've seen the Intellix box and one made by SnapAV (which seems impossible to actually locate for purchase). Thoughts?
bradg33 is offline
post #2 of 17 Old 04-02-2012, 04:00 PM
ericspencer's Avatar
Snap is protected and only sold thru dealers they prohibit internet sales. I have used the intelix pieces and they work well.. they have a revised model out now, but I am not sure its hsipping yet
ericspencer is offline
post #3 of 17 Old 04-02-2012, 07:08 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Audio Authority makes one as well. SnapAV is direct to dealers only.
cshepard is offline
post #4 of 17 Old 04-03-2012, 11:30 AM - Thread Starter
bradg33's Avatar
I found someone willing to sell me a SnapAV one, but the damn thing is over $500. I'll look into Audio Authority.
bradg33 is offline
post #5 of 17 Old 04-03-2012, 11:31 AM - Thread Starter
bradg33's Avatar
Would you say the Intellix ones are worth the nearly $300?
bradg33 is offline
post #6 of 17 Old 04-03-2012, 01:16 PM
If you can get a set of intelix for $300 thats a great deal!
post #7 of 17 Old 04-03-2012, 02:02 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
If you are looking at websites for the Intelix units, a lot of them are priced individually for the transmitter and receiver.
All the coax extenders are priced very similarly.
ifor is offline
post #8 of 17 Old 04-03-2012, 03:50 PM
Joe Fernand's Avatar
Quoted: 280 Post(s)
Liked: 164
Low volume production means these are always going to be more costly than HDMI over Twisted pair!
Joe
Octava Inc. Multi-cast HD over LAN solutions for Residential and Commercial installations.
Joe Fernand is online now
post #9 of 17 Old 04-03-2012, 05:02 PM
crabra's Avatar
I've used THIS one before. Worked great.
crabra is offline
post #10 of 17 Old 04-04-2012, 08:11 AM - Thread Starter
bradg33's Avatar
Any idea on price and where I can get one?
bradg33 is offline
post #11 of 17 Old 04-05-2012, 09:03 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Have you seen this one?
Vin
Vin is offline
post #12 of 17 Old 04-11-2013, 11:52 AM
ronaldpalka's Avatar
Any help would be appreciated. Vin, commenter above me, I probably have the same cable service as you, Optimum. I saw many "extenders" etc but nothing with a transmitter and a receiver over ethernet....
Hello. I have a home in NJ (excellent Cable TV service) and a home in South Florida (horrible). This is my idea. Hopefully someone can help me out
In NJ - Scientific Atlanta Cablebox, with its own remote. HDMI, Coax, Red-Yellow-Red, Blue-Green-Yellow, OUT and IR out
wish to connect the cable box to a "DEVICE" (thats where I need help) to the internet via ethernet into the router in NJ....
In FL -" DEVICE " would ideally connect to the internet (hard wired) and would connect to the TV via HDMI. The remote for the cable box in NJ would be used down here and would be controlled through "DEVICE" to change the box channels and features in NJ.
Any suggestions?
ronaldpalka is offline
post #13 of 17 Old 04-11-2013, 11:58 AM
Colm's Avatar
Liked: 94
Originally Posted by ronaldpalka View Post
Any suggestions?
Yeah, post your question once, in one forum. It is generally considered bad form to post the same question multiple times.
FWIW Just Add Power mades devices that will take a HDMI signal, compress it, transmit it over a network, uncompress it, and convert it back to HDMI. But my guess is that using those across the internet might be problematic for a number of reasons.
Colm is offline
post #14 of 17 Old 04-11-2013, 11:59 AM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
Any suggestions?
Slingbox
http://www.slingbox.com/
jautor is offline
post #15 of 17 Old 04-11-2013, 12:21 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Any suggestions?
The device I linked to is for transmitting HDMI from room to room over coax....a Slingbox, as Jeff suggested, is what you're looking for.
Vin
Vin is offline
post #16 of 17 Old 04-11-2013, 12:50 PM
Slingbox would only connect if I hooked it up to a laptop, smartphone and would not be the best as the remote is on the screen. Perhaps this idea?
Maybe anything that will stream the cable coax signal over the internet in NJ, then something that will take it from the internet in FL turn it back into coax and have the cable box down here?
post #17 of 17 Old 04-11-2013, 08:13 PM
SAM64's Avatar
Liked: 78
No, you cannot practically take 1 GHz of cable bandwidth and 'stream' it over a consumer internet connection....think about it a little.
SAM64 is offline
Reply Home A/V Distribution
