Old NuTone 3-wire intercom radio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-05-2012, 10:38 AM - Thread Starter
brettvdi's Avatar
Is there any affordable way (rental house) to use this system with digital content? I was thinking of running a the second zone from my receiver to this and piping it through the house using the existing wire. It's a just a temporary solution. Is this possible?
Thanks in advance
Brett
brettvdi is offline
post #2 of 12 Old 04-05-2012, 12:11 PM
jautor's Avatar
Quoted: 1336 Post(s)
Liked: 855
Does the unit have an audio input? I'd think either directly connecting a Sonos (if there's an input), or a Sonos plus a personal FM transmitter (if no input).
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #3 of 12 Old 04-05-2012, 01:39 PM - Thread Starter
brettvdi's Avatar
No Audio input (at least on the outside) It's pretty old. I didn't think of a transmitter, that might be the way to go. Great idea.
brettvdi is offline
post #4 of 12 Old 04-05-2012, 02:35 PM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
That's pretty old. Does it still work well enough?
You may just want to consider 2-3 zones of Sonos.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 12 Old 04-05-2012, 02:57 PM - Thread Starter
brettvdi's Avatar
It works great actually. I just want to get rid of the radio and or update it using the existing wiring while not spending a ton of money.
brettvdi is offline
post #6 of 12 Old 04-05-2012, 03:43 PM
jautor's Avatar
Liked: 855
Yeah, just an FM transmitter, one Sonos box, set up a Pandora 80's mix channel and it'll be just like new!
jautor is offline
post #7 of 12 Old 04-05-2012, 06:50 PM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
Maybe you can hang an old, beat up, cardboard box over the master controller, so it will look nicer.
Neurorad is offline
post #8 of 12 Old 04-05-2012, 07:00 PM
jautor's Avatar
Liked: 855
Or a museum plaque next to it explaining its historical significance...
Been very tempted to put one of these up in the back yard:
jautor is offline
post #9 of 12 Old 04-05-2012, 08:42 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
Why not replace the master unit with a new Nutone model? The NM100 will work with the 3 wire and has 2 inputs to add to the tuner.
ifor is offline
post #10 of 12 Old 04-05-2012, 10:26 PM - Thread Starter
brettvdi's Avatar
Ha! This gave me a good laugh. Too bad it's not like the hot tub time machine
I'm pretty sure if I push it hard enough it will just fall in the wall. At that point I can probably tie cans to each end of the wires and just have the intercom! Man I hate renting.
If it wasn't a rental I would put some money into it but I wouldn't throw anyone more money at this place. If I could take the nm100 with me and know that I would use it, it would be a great suggestion so thanks.
brettvdi is offline
post #11 of 12 Old 04-06-2012, 01:56 AM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
Sorry, I didn't see that it was a rental home.
ifor is offline
post #12 of 12 Old 04-06-2012, 04:09 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
In full disclosure, my old, unused, dead M&S intercom looks similar, and I own my house.
Just waiting for the kitchen remodel to start.
Neurorad is offline
Reply Home A/V Distribution
