Amp help for an apple wha - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-07-2012, 04:51 PM - Thread Starter
premium0521's Avatar
Hi guys. I'm looking to setup a simple multi zone system. I plan on using airport expresses as my zones and then iPhones and iPads as sources. I need help finding an amp.
I would like 4 to 6 zones and be able to turn it on and off with my iPhone. I have everything stored in the basement under the steps so I don't want to have to go down there all the time or have to have a bunch of remotes. Thanks
premium0521 is offline
post #2 of 3 Old 04-12-2012, 01:17 PM - Thread Starter
Is there an auto sensing amp that will work for me? It seems like I could get multiple audio source amps but I'd prefer just one amp if possible.
post #3 of 3 Old 04-12-2012, 05:59 PM
jautor's Avatar
Quoted: 1319 Post(s)
Liked: 844
HTD has multi-channel auto-sensing amps... Although between the amp and the airport expresses and the complexity that will bring (and somewhat inflexible), you should really be looking at a WHA system. Look at the HTD MCA-66 system and the HTD-Net iDevice control.
http://www.htd.com/Products/mid-leve...ller-Amplifier
Then just a few Airports that you can select for any combination of zones.
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
Reply Home A/V Distribution
