Hi, don't know if this is the correct place for this question...
So I am setting up a classroom with 25 monitors and have seen that using cat5e is no problem. Well I have been having problems. It's one monitor splitting the image to the other 25 monitors.
I am using solid utp cat5e cable.
I ran all the cat5e to a patch panel punch down 568B. At the other end I have it terminated to keystone jacks. I am using an RJ45 to vga (HD15) adapter to connect everything.
I can't post url's so if you go to eforcity . com and search POTHRJ45AD03 you will see what I'm using.
From the patch panel I have 2 foot patch cables with the RJ45 to vga adapter plugging into a 16 port VGA 300Mhz splitter
monoprice .com search 4087
I am using flat panel monitors with a native resolution of 1360x768 and have tried moving it down to 1024x768 and it's a little better but the main issue is a lot of ghosting.
