MULTIPLE DEVICE SENT TO SEVERAL TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-16-2012, 10:59 AM - Thread Starter
gasbie's Avatar
okay guys, I have a home run of rg6 cable for six room straight into the closet. I have 5 camera that I will like to distribute to these rooms. the camera has a dvr, so I want to be able to view live recording from any of the rooms and at the same time be able to view whats on the dvr from any room. I know I need a modulator and some other equipments, but can someone explain to me what I need and how to go about the connections. All help will be appreciated.
gasbie is offline
post #2 of 2 Old 04-16-2012, 11:16 AM
gregzoll's Avatar
Liked: 33
You would need a MUX or Multiplexer for short. Best bet would be if you have a tablet like a iPad or Android, or smartphone, use it. Otherwise you can feed into a computer running some flavor of HTPC software to do the task for you.
gregzoll is offline
Reply Home A/V Distribution
