Rookie Needs Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2012, 09:57 PM - Thread Starter
Spango's Avatar
Hey all, I've trolled these forums for a long time and have always found it helpful to see how you guys put these incredible home theaters together. We're in the process of building our first home and I have Guardian doing the low voltage wiring and they're going to be installing Klipsch R2650 speakers (5.1 system) in the basement. This is a multi-topic question so here it goes.
  1. Anyone have the 2650's and what do you think?
  2. What kind of a sub should I get to fill the room? Dimensions are approx. 12'x12' with 8' ceilings
  3. What kind of receiver should I be looking for?
My big concern is buying a sub that's too over/under powered for the space. I'm also concerned with buying a receiver that's too over/under powered for the speakers and sub it'll be powering.
I'd greatly appreciate any help. Thanks in advance!
Spango is offline
post #2 of 3 Old 04-17-2012, 12:37 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Ask in the speaker forum.
ifor is offline
post #3 of 3 Old 04-17-2012, 04:12 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Or ask in the General Home Theater & Media/Game Room subforum.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Home A/V Distribution
