Nuvo Concerto Configurator Software - Get it HERE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 04-18-2012, 01:18 PM - Thread Starter
COREi7's Avatar
Thought I'd throw this out there for all you Nuvo users. I managed to source what I'm told is the latest Nuvo Concerto Configurator software. Here's the link.
http://dl.dropbox.com/u/69623915/Con...ator_V1_71.zip
Got it directly from Nuvo, and what's contained in the link above is the unaltered zip file they gave me.
Hopefully this will help some of you out looking for the software as I was.
COREi7 is offline
post #2 of 26 Old 04-18-2012, 05:02 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Haven't installed the sw in a while, but isn't there a EULA that you agreed to?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 26 Old 04-18-2012, 05:08 PM - Thread Starter
COREi7's Avatar
I never agreed to any EULA. The software link was given to me by NUVO without any terms or conditions attached or expressed in the message.
I actually hadn't even opened the zip or installed it myself (until now). You don't have to download it if you think there's anything questionable about it.
I don't believe there is, but then who am I?
Here is the text contained in the README.TXT file contained in the ZIP. I don't see anything here restricting distribution.
Just trying to be helpful and share whatever I find.
Concerto Configurator Installation ZIP
This ZIP archive contains the files necessary to install
the Concerto Configurator application from NuVo
Technologies. This application allows the user to
create configurations for the NuVo Concerto distributed
home audio system.
System Requirements
An application capable of extracting files from a ZIP
archive (WinZip, PKZip, WinRar, etc.)
Windows 98 SE, Windows ME, Windows 2000, Windows XP
5 MB available disk space
(50 MB if Microsoft .NET Framework 1.1 upgrade is needed)
800x600 256 Color video resolution minimum
400 MHz Celeron processor or better
(1.0 GHz recommended)
Installation Instructions
1. Save the "Concerto Configurator Install Email.zip" to
a folder on the hard drive.
2. Extract the files from the ZIP into the folder.
3. Start "Setup.exe"
Note: it may take a few moments for the installer to load.
4. Select OK to start installation. Note: if Microsoft
.NET Framework 1.1 is not installed, a link to the
Microsoft update site will be displayed. This process
will take a few minutes (depending on connection speed)
and may require a reboot.
5. Select Next> on each page. The default setting can be
used or you can change the settings as needed.
"Disk Cost.." allows you to view how much disk space is
required on each of your disk drives.
6. Click Close to finish the installation.
Notes
Administrator privileges are needed in order to install the
Microsoft .NET Framework upgrade. No special privileges are
needed to install or run the Configurator.
COREi7 is offline
post #4 of 26 Old 04-18-2012, 05:29 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
As long as that's a link provided by NuVo, I guess it's up to them. I was going to tell you that you can get the config SW from NuVo tech support anyway.
Note that this software is for the Concerto, NOT the Grand Concerto, which is at v2.66p.
Jeff
jautor is offline
post #5 of 26 Old 04-25-2012, 12:02 AM
crisms98's Avatar
I had my GC sent in to Nuvo for repairs (power supply and ipod dock problems) and asked for a copy of the configurator (2.66) and they gave it without question.
crisms98 is offline
post #6 of 26 Old 09-01-2012, 04:44 PM
ddohm's Avatar
The link appears broken, and I lost my CD. Any chance you can repost?
DavidDohm
ddohm is offline
post #7 of 26 Old 09-04-2012, 09:10 AM - Thread Starter
COREi7's Avatar
I've restored the link. Should be working fine again.
COREi7 is offline
post #8 of 26 Old 09-29-2012, 01:08 PM
JeffGoos's Avatar
Thanks for posting.
So this is NOT for the grand concerto, only the concerto?
Maybe someone can help clarify how all this works with Nuvo. I know they want to protect their dealers/installers and therefore don't openly offer their configuration SW to the public. However I'm planning on pulling the trigger on a grand concerto with expander (NV-I8GMS & NV-I8GXS) in December/January. It may or may not come from an authorized seller. The authorized sellers say they only sell to dealers. I'm not a dealer of course, just a HA enthusiast. But I will need this configurator SW to set it up no matter who I buy it from.
Am I screwed, and therefore need to buy Russound instead? Can I call their tech support and ask for it? Do I need to beg or pay someone for it?
I'm also in the same boat for the NV-T2DF tuner configuration SW...
Thanks in advance.
JeffGoos is offline
post #9 of 26 Old 09-29-2012, 02:31 PM
jautor's Avatar
Liked: 777
When you pull the trigger, just email NuVo tech support and ask for a login to the ProZone where they keep the software...
Call a local, authorized dealer and see what they'll do for you price-wise for a DIY install. Just don't expect them to answer a bunch of questions about installation if they're not being paid for doing the work. But I'd certainly want to get the main gear from an authorized source to avoid warranty hassles. And that dealer can certainly supply the software as well.
Jeff
jautor is offline
post #10 of 26 Old 10-02-2012, 09:20 PM
JeffGoos's Avatar
Hi Jeff
It appears the Nuvo web site does not have a tech support email address. Just a generic customer service email for "updates on order status, NuVo University, or shipping and service issues" and a sales email. Is there a secret email somewhere or do I just need to pick up the phone and call them? I'm an engineer so I can handle the electronics part easily.
I'm reading several threads over at Remote Central where it sounds like Nuvo does NOT give this software out to anyone but an authorized dealer through their Prozone web site. They sound quite strict about it actually.
BTW, is Automated Outlet still an authorized reseller? They used to be but their site now has very little product listed.
Thanks again
Jeff
JeffGoos is offline
post #11 of 26 Old 10-02-2012, 11:58 PM
jautor's Avatar
Liked: 777
techsupport@nuvotechnologies.com
I don't believe Automated Outlet is an authorized dealer any more...
Jeff
jautor is offline
post #12 of 26 Old 07-20-2013, 12:19 PM
LoveToRide's Avatar
Is there a Mac version of the configurator software?
Dan
LoveToRide is offline
post #13 of 26 Old 07-20-2013, 12:49 PM
jautor's Avatar
Liked: 777
Dan
No.
jautor is offline
post #14 of 26 Old 07-30-2013, 11:01 AM
alexandreroland's Avatar
guys I'm new to the forum, my software does not work with version 1.71 is the concert i8DLS not connect or killing.
solving, etc. My cables are excelent.
alexandreroland is offline
post #15 of 26 Old 10-06-2013, 10:18 AM
cl601amt's Avatar
Any chance the link could be restored?
I bought a house with a Concerto system and want to change the presets.  Nuvo tech support was not very helpful, pushing me to a dealer who will not return my call.
TIA
cl601amt is offline
post #16 of 26 Old 11-14-2013, 07:14 AM
ikayhan's Avatar
Hi,
Thanks for posting the link for Concerto configurator software here last year. I just tried the link and it is not there anymore. Would it be possible to share it again?
Thanks a lot
ikayhan is offline
post #17 of 26 Old 05-27-2014, 11:10 AM
flygirlsguy2's Avatar
I'm new looking for the configuration software. Looks like the link is broke.
flygirlsguy2 is offline
post #18 of 26 Old 05-27-2014, 11:30 AM
jautor's Avatar
Liked: 777
The Grand Concerto configuration software is now available on the new Legrand / NuVo site:
http://www.legrand.us/nuvo/audio-video/wired-audio-systems/nv-i8gm.aspx#.U4TLZ_ldXh4
jautor is offline
post #19 of 26 Old 05-27-2014, 11:33 AM
That link is just for the Grand Concerto not the Concerto. I did try it anyway but it it work. It could be I have the wrong cable. I have a db9 straight thru not a null. Anyone know what that cable should be?
post #20 of 26 Old 05-31-2014, 05:58 PM
Follow up! The software for the concerto and grand concerto are online at the mfg website. Assure you have the correct one as they can't be switched.
post #21 of 26 Old 05-31-2014, 06:57 PM
jautor's Avatar
Liked: 777
Nice find! I didn't see the option for "discontinued products" in the Resources area. Here's the link to the Concerto ID8 page with the software listed:
http://www.legrand.us/nuvo/audio-video/wired-audio-systems/nv-i8d.aspx#.U4p6L4FdVOE
jautor is offline
post #22 of 26 Old 03-27-2015, 09:41 PM
Liked: 0
NV-M3 Firmware
The NV-M3 firmware is not listed on the site even looking under discontinued products. Does anyone have it? My M3 crashed after adding some music. It was in a loop and I had to use the format function when booting it. Now is says it needs the firmware update from prozone which doesn't exist anymore.
HexRex is offline
post #23 of 26 Old 03-27-2015, 11:25 PM
jautor's Avatar
Liked: 777
Try emailing NuVo tech support, I'd think they'd provide you with a copy given that everything else is readily available on the website...
jautor is offline
post #24 of 26 Old 04-06-2015, 11:22 AM
Liked: 0
Thanks, I emailed them an they sent a link with the firmware. The M3 is now working like a charm!
Here are the details, incase anyone else experiences the same issue:
Below is a link to a zip folder containing the M3 Firmware Loader. After downloading the zip folder, unzip the folder and follow the steps in the readme file. You will connect your Windows computer to the M3 with a USB connection.
(due to nubie status, I can't post links yet, so just add the http and w's to the URL below)
nuvoaudio.com/downloads/software/NV-M3_Firmware_Upgrader_v1_60.zip
When the M3 boots up, the bootloaders will still display v1.40. After the M3 boots up, you can verify that the v1.60 firmware loaded onto the M3 from the following menu option on the front of the M3: Main Menu > Settings > Version. The Master and all Slave bins should have v1.60 firmware (there will be numbers after the v1.60, but they should each begin with v1.60...).
HexRex is offline
post #25 of 26 Old 07-18-2015, 01:42 PM
Liked: 0
Trying to hook up laptop to Nuvo
Hello,
I've moved into house with nuvo concerto system NV-I8GM, that also has NV-M3. All looks to be circa 2008. I'm trying to figure out how to hook up my laptop and play internet radio through the system, but am not having any luck. Outside of getting the Nuvo Gateway, is there anything I can do?
Tom
motyfoog is offline
post #26 of 26 Old 07-18-2015, 04:03 PM
jautor's Avatar
Liked: 777
Does your laptop have a stereo line output jack (or a headphone jack that can be configured as a line out)?
If not, get a USB soundcard to get a stereo line out and connect it to one of the inputs on the GC.
jautor is offline
Reply Home A/V Distribution
