approx cost to have in-wall wiring installed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-18-2012, 05:53 PM - Thread Starter
jontyrees's Avatar
Liked: 38
Hi - I know I'll get the "we need more info" responses, but I'll ask anyway. If I were to have speaker wire run from a terminal in back of my receiver, in-wall, to terminals in the locations for a 7.1 system, ball park what should I expect to pay an installer? This is in an approx 25x15 foot room with 9ft ceilings, and a lit fairly open attic above. $200? $500? $1,000? Not looking to go with in-wall speakers at this time.
Just trying to get an idea. I'll get an actual quote, but I'd like a frame of reference.
jontyrees is offline
post #2 of 11 Old 04-18-2012, 06:20 PM
gregzoll's Avatar
Liked: 33
Prices vary area to area. Do it yourself, and you will save wads of cash.
gregzoll is offline
post #3 of 11 Old 04-18-2012, 07:09 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
$75-95/hr., I'd say 6 hrs. off the top of my head.
cshepard is offline
post #4 of 11 Old 04-18-2012, 07:16 PM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
If attic is unfinished, this is relatively ez DIY. If finished attic u may have to pull things out thereby adding cost & time.
MrBobb is offline
post #5 of 11 Old 04-19-2012, 09:30 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
It would take an electrician an hour to wire that, but the drywall guy would take about 3 hours to fix his mess. It may be cheaper to fix drywall and repaint, than hire a LV installer.
The pro LV guy could probably do it all without cutting drywall, but it will take a pair of guys 4-6 hours, at $80-200/hr.
Those are my best guesses.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 11 Old 04-19-2012, 10:20 AM
ljo000's Avatar
My builder charged $50 per run of any A/V wire (Cat5e/Speaker/Coax etc), terminated however I wanted. I had to pay for the patch panel but they included any wall plates and wall boxes.
That's in MA BTW and this was all done with the walls open.
ljo000 is offline
post #7 of 11 Old 04-19-2012, 11:48 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
That sounds about right.
As usual the case, the painting doesn't take much, it's the preparation and the clean up that takes the most effort.
MrBobb is offline
post #8 of 11 Old 04-21-2012, 05:08 PM
ELECTRICDON's Avatar
Lmao... Just substitute auto mechanic for electrician and substitute car salesman for pro lv guy and it would be even funnier.
ELECTRICDON is offline
post #9 of 11 Old 04-22-2012, 07:27 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Well, an auto mechanic would probably try to avoid cutting drywall. Seems like electricians cut drywall at every opportunity.
Neurorad is offline
post #10 of 11 Old 04-24-2012, 08:31 AM - Thread Starter
jontyrees's Avatar
Liked: 38
Thanks all for the responses. I got it done and it went like this: one guy, (young A/V guy, sole proprietor I think, randomly called from Craigslist), $90 first hour, $60/hr thereafter, 5hrs (!) = $330, plus cost of wall plates, speaker wire, etc - total came to $440. Oh, and that included hooking up HDMI to my mid-ceiling projector.
It would have taken me forever to do it and I would have put my foot through the ceiling, although I would have paid ~$3 apiece for the wall terminal plates from Monoprice instead of $15 apiece from Lowe's.
At the end of the day, I'm happy it's done, and the cost wasn't prohibitive.
post #11 of 11 Old 04-24-2012, 08:42 AM - Thread Starter
jontyrees's Avatar
Liked: 38
BTW, the installer was apologetic about the cost of the wall plates from Lowe's - he uses Monoprice, but this was a quick turnarounf thing, and he only had the kind that allow a speaker wire to pass through a split rubber grommet, so he picked up the more permanent kind with speaker terminals on his way to my house. Maybe Radio Shack would have had cheaper ones, maybe not.
Reply Home A/V Distribution
