Mono Audio needed in every room of House... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-21-2012, 06:59 AM - Thread Starter
joebrez's Avatar
Good Moring,
I have a house that already has internal audio installed. Each Room has a volume control and 1-2 speakers installed. The odd thing, all runs only have 2 wire runs to each room, essentially a MONO setup. I'm guessing the design was due to some rooms only having one speaker (bathrooms etc.). The problem is my receiver doesn't have a MONO mode. So I only hear one side of the track.
My setup is an iPod in a iPod docking station outputting to a 1/8 stereo to dual RCA cable, which is fed into the AUX ports of an older Kenwood VR-405 receiver. Being that the house is not fitted with conduit, running the additional source line to the volume controls will be very costly.
Is there an easy and inexpensive way to convert the output from the Kenwood into a Mono signal? I did try a Radio Shack Stereo to Mono converter running off the iPod dock, but would not output anything but a rhythmic clicking noise. I removed the adapter, and sound returned. Yes, odd I know.
I've heard about the resistor method, but also heard sound quality is greatly reduced.
Just looking for ideas
Thank!
joebrez is offline
post #2 of 7 Old 04-21-2012, 07:22 AM - Thread Starter
joebrez's Avatar
I just had an idea, don't know if anyone has tried it.
What if I took the stereo RCA signal from the ipod into a RCA Y Cable that takes the signal from stereo to mono, then another Y cable that takes the Mono back into two signals for the amp? Would that work?
joebrez is offline
post #3 of 7 Old 04-21-2012, 07:58 AM
SAM64's Avatar
Liked: 78
Did you connect this device to the outputs? You were probably hearing the protection relays clicking
Resistors don't reduce sound quality.
You need to make the line level source mono by combining both channels, through series resistors.
If you can solder, you can do this for a few pennies.
SAM64 is offline
post #4 of 7 Old 04-21-2012, 08:36 AM
Glackowitz's Avatar
here is a link to a stereo to mono signal converter in line level
would need one on each source
http://www.audioplex.com/llsc1.htm
or
something like this on the speaker outputs at the main receiver
http://www.audioplex.com/MonoMixer.htm
Glackowitz is offline
post #5 of 7 Old 04-22-2012, 05:58 PM - Thread Starter
joebrez's Avatar
[quote=Glackowitz;21934122]here is a link to a stereo to mono signal converter in line level
Thanks. I sent the company an email with recommendation on both devices.
joebrez is offline
post #6 of 7 Old 04-23-2012, 12:42 AM
stefan.hallen's Avatar
I did it without soldering... Very simple, based it on this guys designs: http://www.rane.com/note109.html
stefan.hallen is offline
post #7 of 7 Old 04-23-2012, 12:43 AM
Absolutely not. Never use Y cables to combine signals, you might destroy your equipment.
Reply Home A/V Distribution
