80' HDMI run and Repeater / Extender - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-27-2012, 09:26 AM - Thread Starter
mmurrell's Avatar
I'm looking to run video from my Receiver in the wall to my tv hanging 35 feet away. Due to vaulted ceilings and wall runs I think I need 70 feet total but I don't want to short it.
while I have run 50' in a single cable with no issues, I'm not sure about running 100' strait cable, even if it says it's got an inline booster (eg this or this). Should I use something like that or a HDMI Extender / booster?
Also, if I use a booster does it have to go in the middle of two shorter cables or can I put it on either end?
The eventual media will be HD cable tv, Xbox, blu ray, and wii all switched and controlled from the home theater receiver, and output via A single hdmi run to the tv.
Thanks for any advice...
mmurrell is offline
post #2 of 4 Old 04-27-2012, 12:47 PM
scl23enn4m3's Avatar
How about instead of an HDMI cable you run a few Cat 6/5e cables and use some HDMI baluns on each side? It will definitely be the more reliable option.
scl23enn4m3 is offline
post #3 of 4 Old 04-27-2012, 03:06 PM
Arcticbear84's Avatar
For 80ft, I think you have to use 24AWG to get reliable transmission.
The second link you provided is for a 24AWG, but the seller has low stars.
You can either get just a 24AWG cable with an HDMI Extender or
a balun, HDMI over CAT extender
Arcticbear84 is offline
post #4 of 4 Old 04-27-2012, 04:09 PM
jautor's Avatar
Quoted: 1221 Post(s)
Liked: 782
Concur that at that length you should be looking at a balun solution. Suggest you look into an HDBaseT product. Monoprice has one for <$200. Only needs 1 Cat5e cable. But if this is new construction (not a retrofit), I would recommend you run 2-3 Cat5e/Cat6 to a new projector location anyway, as well as a flex conduit for "the future".
Jeff
jautor is offline
Reply Home A/V Distribution
