1920's Duplex Renovation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-27-2012, 03:11 PM - Thread Starter
mattlikesbikes's Avatar
My wife and I recently purchased a duplex to owner occupy, with the plan that in 4-5years we convert to a single family home. This is a top/bottom duplex and we are taking over the downstairs. We are starting with a full gut though so we can insulate and ditch the knob and tube electric. So while the sheet rock is off I can start the install for the eventual whole house audio.
So I've got some plans going for how and what I want, but needed some help with a few key elements.
1. Sound creep from ceiling speakers. We don't want to piss off the upstairs tenant. Should I box in, or do some level of sound proofing directly behind speakers to keep the floors above from feeling or hearing too much? The house has the original oak floors and no real sound insulation between levels.
2. Is 11' x 11' too small for a home theater room? Nothing crazy for the room, just our current 46" TV and either a 5.1 or 7.1 system (7.1 too much?). Just for netflix/movies/PS3.
3. For my mid room speakers (should I go 7.1) can I make them double duty? IE can I wire them into the TV room receiver and the whole house?
4. Do you really need multiple speakers in rooms if the goal is just ambient music? I can cut my speaker budget in half by just going to one speaker in the bedroom, dining-room and kitchen. If I decide to add a second later, can I wire it in series with the existing speaker?
I am looking at HomeTech for volume knobs and the junction box. And maybe Polk for the ceiling speakers.
mattlikesbikes is offline
post #2 of 2 Old 04-27-2012, 04:25 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
You should be concerned. I don't know if just boxing in the speakers will be enough. I'd be very careful here, contact Ted at The Soundproofing Company (here's here, mostly in the Theater Construction subforum) to discuss this with a real expert before doing anything.
Never too small... Doing 7.1 is usually an issue about speaker placement, not room size. If you can find locations for the 7.1 speakers, go for it.
Yes, wire them like this: (diagram uses NuVo's term for the interrupt device)
Bleeechhhh!
Do stereo speakers - if anything it allows better coverage at lower volume, so you get more even coverage in the room. If you do one speaker, adding another will be problematic, as placement for one speaker is very different than for a stereo pair. There are inexpensive speakers (Monoprice) - and it's easier to upgrade the speakers later if you choose than to try to undo a single-speaker arrangement. Swap is easy - adding requires drywall work/repair.
For bedrooms, think about placing in-ceiling speakers at proper "surround" locations (instead of centered in the room) if there's a TV planned. Then you can use the interrupt scheme (as above) later if desired. I wired all of my bedrooms in this manner just in case. It also places the in-ceiling speakers on either side of the headboard, so works well for music as well. Assuming the room has an obvious furniture arrangement. I forced the issue by placing wall-mount locations for the TVs.
Jeff
jautor is offline
Reply Home A/V Distribution
