Anyone in Dallas - Professional Wiring Help, will pay $$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-29-2012, 10:33 AM - Thread Starter
Superfluous's Avatar
Long story short, there's some existing wiring, but not the correct stuff I believe for what I need to do and I think I'll have to have some new cat6 and whatever else I may need wired through the wall/ceiling.
My troubles are chronicled here:
http://www.avsforum.com/avs-vb/showthread.php?t=1407136
http://www.avsforum.com/avs-vb/showt...1272288&page=9
Are there any professional AV/wiring people that could do this for me? I would pay an agreed price.
Superfluous is offline
post #2 of 13 Old 04-29-2012, 03:56 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
I'd get some names from the CEDIA website.
Using the drywalled garage below for access would be pretty easy, and it's dirt cheap to repair drywall. Might be super easy if the floor joists are parallel to the run.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 13 Old 04-29-2012, 08:19 PM - Thread Starter
I'm having them start painting tomorrow... and I thought maybe they could pull up the shoe molding and wire it behind there or possibly behind the entire baseboard. Is this feasible?
post #4 of 13 Old 04-29-2012, 08:44 PM
scl23enn4m3's Avatar
There won't be enough room behind the shoe moulding. The baseboard is possible but then you're still going to have sheetrock damage pulling it out and you'd have to glue back to avoid nails (if you can salvage the original).
If you're accepting of using moulding to hide the cables, why not use this as an excuse to install some crown moulding in that room? Since you have a fireplace below you're TV, it'll be easier to route the wires up instead of down. Depending on how much time you want to invest, you could even do it on your own. The hardest part of the job would probably be cutting and installing the crown, but even for that there are plenty of short cuts nowadays.
scl23enn4m3 is offline
post #5 of 13 Old 04-29-2012, 08:59 PM - Thread Starter
They are actually installing crown molding. How would I have them do the cable with that though?
post #6 of 13 Old 04-30-2012, 04:23 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Usually a gap behind crown molding.
Most people don't want to run new cables because it's a pita to fix drywall yourself, and paint. Since you're painting anyway, I would reschedule the painters until you have the cables installed.
DIY Drywall repair can be frustrating and time consuming, if you're not experienced. Hiring someone to do it is very easy.
You can cut holes in the drywall at the top of the walls, and hide the holes behind the crown molding. And, you could run the cables around the room behind the crown molding.
Just reschedule the painters until you have the cables sorted out, and avoid the cost of the crown molding. if you were doing crown molding yourself, there would be less of a chance to nail a cable, but that is a concern.
You can run the cables in the drywall ceiling, below the floor in the garage ceiling, or behind crown molding. You have lots of options.
Neurorad is offline
post #7 of 13 Old 04-30-2012, 04:29 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
And yes, behind baseboard is also pretty easy. Pull the baseboard, cut a 1-2" channel in the drywall, and the cables fit in that channel. But careful of nailing cables. If you DIY the cable installation, and have the time, you can drill holes in the center of the exposed studs behind the baseboard and channeled drywall, and install nail plates on the drilled studs; the cables pass through the studs this way, and there is less of a chance for cable damage from nails.
Neurorad is offline
post #8 of 13 Old 04-30-2012, 05:37 PM - Thread Starter
We're going to do it through the crown molding as it's being installed.
How do we deal with the cable going through the corner of the room? I feel like we can cut through the wall for the protruding corners, but what about the concave corners (two of them)?
How do I fix them to the wall properly? Cable staplers? I don't want to damage the cables. I'm planning to put 1 STP Cat6A and 2 UTP Cat6 cables in it. The cat6a are thicker, I believe.
Any additional tips?
post #9 of 13 Old 04-30-2012, 06:03 PM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
Make sure the cables will fit behind the crown molding profile you choose.
Run it by the trim carpenter first.
Don't staple category cables.
Test the cables ASAP, to make sure they're not damaged.
I'm not sure if you can bend a category cable 90 degrees, and have peek performance, i.e. 10Gig data speed. Supposed to be gentle bends. Will most probably be fine for gigabit, not sure of 10Gig. I have no experience with 10Gig.
In 10 years, and you attempt 10Gig, and it doesn't work, will be easy to add more cables through the garage ceiling drywall.
Neurorad is offline
post #10 of 13 Old 04-30-2012, 08:18 PM - Thread Starter
Hopefully I won't still be living there in 10 years!
If I shouldn't staple them, how should I fix them? Can I cut the wall corners to avoid sharp bends or is that a bad idea?
post #11 of 13 Old 05-01-2012, 06:45 PM - Thread Starter
bump, need help with how to fix it to the wall if I can't staple it.
post #12 of 13 Old 05-01-2012, 06:53 PM
jautor's Avatar
Quoted: 1319 Post(s)
Liked: 844
You can staple them in place - just use a cable tacker which has rounded staples for this exact purpose. But assuming you're just trying to get them in place so they're not hit by the carpenter - duct or masking tape!
And by "sharp corner", we mean a real 90-degrees - don't do that. But a bend radius of 1" or so isn't bad. Hold the wire in your hand and turn it back towards itself, you'll see that you get about 2" of loop width (diameter) without forcing the wire...
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #13 of 13 Old 05-02-2012, 06:41 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
What kind of crown molding trim? Some people use PVC now - not sure if that would allow you to run cables behind it. Conventional, standard wood crown molding trim usually has space.
Discuss it with the trim installer/carpenter. Just pick crown that has plenty of room.
Neurorad is offline
Reply Home A/V Distribution
