Recommendation for speaker selector switch box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-05-2012, 11:34 AM - Thread Starter
SBMongoos's Avatar
Buddy of mine has an older system he likes to keep running. He's got a Vanco SS4 now that is starting to break down and cause problems in his system. Curious of any recommendations to replace this. Doesn't need to be pricey but doesn't want junk either.
SBMongoos is offline
post #2 of 4 Old 05-05-2012, 11:45 AM
scl23enn4m3's Avatar
I'm using the 6 zone Outdoor Speaker Depot one and it's been as solid as a rock. It's a no frills speaker selector, but does a great job at what it's supposed to do.
http://www.outdoorspeakerdepot.com/is6paspseimp.html
scl23enn4m3 is offline
post #3 of 4 Old 05-05-2012, 03:11 PM - Thread Starter
SBMongoos's Avatar
He likes this. Looks like a go. Monoprice deal in these?
post #4 of 4 Old 05-05-2012, 04:38 PM
Not sure what you meant by the Monoprice question (I know they had a 4 speaker one) so I went back to their site and checked it out. It looks like they bought from OSD, slapped their name on there, and cut the price in half. Damn, that could have saved me some money. I'd say just go with the Monoprice one now, there isn't really much on the inside so I'm certain it will be the same.
Reply Home A/V Distribution
