Sonos Failure Rate - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-05-2012, 02:41 PM - Thread Starter
nybroker's Avatar
I have just set up my 2nd zone and out of 5 sonos components 3 of them have been defects.
Both defects were the Connect
The S5 was good out of the box but its only a week old
The first connect bought in January was bad out of the box
The second connect worked for 2 months then began to drop numerous times a day I would have to unplug it to restart. As it got worse and worse initially it was once a week or so so i attributed it to the nework and lately it was like every hour so I contacted support and they confirmed that it had to be returned.
The third connect would not find my network so that went back as well
So three out of four Connects have been returned
Am I just that unlucky or is this a problem with Sonos and the Connect specifically?
nybroker is offline
post #2 of 6 Old 05-05-2012, 08:22 PM
Techphil's Avatar
Bad luck. I've installed hundreds of sonos devices and the only bad piece i had was a zone bridge that was bringing down the entire network after being installed for a week.
Techphil is offline
post #3 of 6 Old 05-05-2012, 09:06 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I'd find out what router and WAP that Sonos recommends, or find out what others have used with good success, at the Sonos forums.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is online now
post #4 of 6 Old 05-06-2012, 04:01 AM - Thread Starter
nybroker's Avatar
Just to clarify the 3 problems were all different
Connect 1-Ethernet port was bad out of the box
Connect 2-Must have shorted out as it worked for 2 months then just began dropping connection. Support had me do the "mute test" and unit was unresponsive so they said it needed to be returned
Connect 3-This would not complete installation when i attempted to set it up
Connect 4- Hooked up and is working fine for 2 days now hopefully this is the last one.
Connect 1/2 were of the same batch as i got it at the same time
Connect 3/4 were also of the same batch as I got those at the same time
nybroker is offline
post #5 of 6 Old 05-14-2012, 06:18 AM
caper_1's Avatar
Liked: 26
sorry for the hijack, but is there a place to get sonos gear for a DECENT price? Retail is outlandish...
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #6 of 6 Old 05-26-2012, 02:19 AM
themoderntheatre's Avatar
I think it's bad luck too. I haven't had a bad Sonos product yet. They do run hot and depending on your setup, I could see one maybe 2 products failing because of heat. As far as connections go, there are so many variables involved that it's too hard to diagnose well.
Sonos margins for us dealers are very slim already. There isn't a lot of money made selling their products, it's about installation and properly designing a system for the customer's needs.
Ryan Siu
Founder, Owner
The Modern Theatre LLC
themoderntheatre is offline
Reply Home A/V Distribution
