Apple TV, outdoor speakers, multiple TVs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-06-2012, 10:57 PM - Thread Starter
Ceedubbadubba's Avatar
Hi all. I'm brand new to this forum. I hope this is the correct place for this thread. If not, please point me in the right direction.
Here is the goal for my setup:
1. Have an indoor and outdoor television, both receiving separate cable inputs from separate boxes.
2. Have outdoor speakers (wired or wireless...I haven't decided yet, and I don't think it matters for these purposes) that can play music directed from my iPad OR receive input from the outdoor TV. I would like to be able to switch between these inputs as I please.
3. Assuming all of this would be made possible only with Apple TV, I'd like to be able to run Apple TV on both of my TVs. If there is a way to use my iPad to remotely control my outdoor speakers without Apple TV, then I don't necessarily have my heart set on having Apple TV.
I have drawn a crude diagram of how I see it working out. I'm hoping someone can:
1. Provide me a reality check as to if this setup would even work.
2. Tell me if there is a more efficient/cheaper way to do this, or if there is are some subtle changes that might give me a more integrated setup.
Thanks everyone!
Attachment 245734
Ceedubbadubba is offline
post #2 of 6 Old 05-07-2012, 12:14 AM - Thread Starter
Sorry, also to clarify: When I say I want to be able to control the speakers (ie control what music is being played...in other words, iTunes), I mean I want to do so wirelessly. That's why I ASSUME I need Apple TV, because I don't think there is any better interface that the iPad will control (but I'm open to hearing differently).
post #3 of 6 Old 05-07-2012, 12:10 PM - Thread Starter
As I'm doing more research, I'm starting to suspect that I might need an amplifier between RCA inputs and the speakers. The input on the speakers is speaker wire (there are +/- leads coming out of the speakers). Is this true that I need an amp? If so, is there a good cheap solution?
post #4 of 6 Old 05-07-2012, 12:35 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
You definitely need an amplifier (sources output at 'line level'). Easiest path is any AV receiver (Onkyo, Denon, etc.) with AirPlay support and an iPad/iPhone control app. Then you hook all of your sources (cable box, AppleTV, etc.) to the receiver which powers the speakers.
Jeff
jautor is offline
post #5 of 6 Old 05-07-2012, 08:09 PM - Thread Starter
Jeff
Thank you for your reply. If I got a receiver that supported AirPlay AND I got an AppleTV, wouldn't that be redundant? Wouldn't getting one or the other do the job (ie an AirPlay equipped AV Receiver OR a non-network receiver with AppleTV). The reason I ask is that the price difference between AirPlay equipped receivers and non-network receivers appears to be ~$200. Given that AppleTV is only $100, it seems like it might make sense to buy a cheaper AV receiver and AppleTV, thus saving myself $100 and having the ability to mirror my iPad screen if desired.
If I am way off, please let me know. I am such an amateur on this stuff and I may be getting bad info via google! Thanks!!!
Chris
post #6 of 6 Old 05-07-2012, 08:24 PM
jautor's Avatar
Liked: 777
Sorta, yeah... (should have said either/or)
If you want to control the AVR with your iPod/iPad, it will need to be a network receiver to have IP control. Otherwise you're looking at IR repeaters or other 3rd party solutions, and won't be able to use the pre-built apps for control. The network receivers also have lots of Internet music services built-in, which will include lots of stuff not in the Apple universe.
Jeff
jautor is offline
Reply Home A/V Distribution
