What do you like for termination blocks? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-14-2012, 09:25 PM - Thread Starter
lahatte's Avatar
I am wiring my house for audio, video, automation, etc. I am thinking about trying termination blocks. What do you like to use for these applications regarding terminal blocks? I'll have Cat5e, coax, speaker wire, etc.
lahatte is offline
post #2 of 8 Old 05-14-2012, 09:35 PM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
You mean patch panels.
Terminal blocks might be useful for patching audio - I suggest barrier/Buchanan terminal blocks for this purpose.
For patching category cables, you'd use a category cable patch block.
Try searching using patch + block or patch + panel.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 8 Old 05-14-2012, 10:19 PM - Thread Starter
lahatte's Avatar
Thanks. If you know of some links to items for sale, that would help too. A picture is worth a few dozen words?
lahatte is offline
post #4 of 8 Old 05-14-2012, 10:20 PM - Thread Starter
lahatte's Avatar
Oh. What about for telephone/PBX?
lahatte is offline
post #5 of 8 Old 05-15-2012, 04:37 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Will you use a low voltage enclosure, a wall mount rack, or a simple piece of plywood screwed to a few studs in a mechanical room?
There are a variety of options for patching phone lines (usually category cables), category cables for Ethernet, and audio (most people don't patch audio cables; the speaker cables are usually run straight to the amp or speaker selector box).
Patching adds a level of complexity that for some people isn't necessary; running category cables for ethernet, from each room, straight to the switch is common. A patch panel allows for easier changes to a configuration - not common in a residential setting.
Leviton, and many other manufacturers, have removed the complexity of 110 blocks for phone category cables in the mechanical room, and replaced them with simple modules/brackets. These devices can be easily snapped into the perforated back of a low voltage enclosure. Spend some time searching online, and visit the low voltage aisle of Home Depot or Lowes to see what's available.
Neurorad is offline
post #6 of 8 Old 05-15-2012, 06:40 AM
gregzoll's Avatar
Liked: 33
monoprice, parts express, markertek, and there are others. If you want something simple, use the Leviton panels.
gregzoll is offline
post #7 of 8 Old 05-15-2012, 11:42 AM - Thread Starter
lahatte's Avatar
Ok. Thanks for the information. I will look for the low voltage panels and see if I get some ideas from those. I don't yet know if I will really need these panels, so we'll see.
lahatte is offline
post #8 of 8 Old 05-15-2012, 11:56 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
That Leviton phone module/bracket, detailed above, is not a patch panel; it's for connecting all your phone cables to a single (or multiple) incoming lines. You'll need something like that, if you want landline phones.
Neurorad is offline
Reply Home A/V Distribution
