Monoprice 1x4 HDMI Splitter CatX solution kit any good? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-25-2012, 05:41 PM - Thread Starter
Aslan's Avatar
Location: White Bear Lake, MN ----- CUSL2C, P3/1.0, 256Mb, HiPix, A2496, D50Q, Stewert 1.3g, Denon 3801,
Like so many others, I'd like to distribute A/V from a STB to TV's in bathroom & offices. Runs are 45', 55', 60' and 80'. One possible and easy solution is:
Along with some 100' 24awg ethernet cables. Cost wise it's a pretty cheap solution (too cheap?). Has anyone used it? Know how well it works? How closely sync'd would audio be on all of the TV's?
Aslan is offline
post #2 of 2 Old 05-25-2012, 09:08 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 782
Audio sync between the displays will be a function of each display, not the splitter. Cable length deltas are inconsequential (speed of light and all that)... If the TVs are same brand/model (or similar in the product line), they'll probably be fine. Ones from different makers, or different model years / families, may not sync so well. But if they're in other rooms, it's no big deal.
Jeff
jautor is offline
Reply Home A/V Distribution
