Please tell me someone has figured out IR/DirecTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-29-2012, 06:25 PM - Thread Starter
fax6202's Avatar
I have yet to find a concrete answer to what IR setup will work with DirecTV. If anyone has a solution please share. Especially if is with HotLink or Xantech. Thanks.
fax6202 is offline
post #2 of 9 Old 05-29-2012, 06:30 PM
Neurorad's Avatar
Quoted: 223 Post(s)
Liked: 140
Have you searched dbstalk DirecTV forums?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 9 Old 05-29-2012, 06:45 PM
jautor's Avatar
Quoted: 1125 Post(s)
Liked: 738
Most any of them. Only issue I know of for D* receivers is that some models are sensitive to "overdriving" the IR (too much signal). Fixed by placing the emitter a small distance from the eye.
What are you trying to do? D* HD receivers also support RF remote control if you buy the ~$40 RF-capable remote, for example. Much easier route if all you need to remotely control is a D* receiver.
Jeff
jautor is offline
post #4 of 9 Old 05-29-2012, 06:56 PM - Thread Starter
fax6202's Avatar
Thanks Jeff.
I have used RF before and it works although the lag is a little frustrating. I am going to get one of the harmony's to control the AVR, BluRay, D* receiver, etc. I have just heard of so many systems have issues with D*.
although the Niles system seems to really work. I would rather go w/ xantech however
fax6202 is offline
post #5 of 9 Old 05-29-2012, 08:11 PM
jautor's Avatar
Liked: 738
Xantech gear will work fine. Again, only issue I know of with IR on D* is placing the emitter perhaps 1/2" away from the eye opening (if directly over isn't working well). Lag from RF/IR is more on the D* software than the remote...
Jeff
jautor is offline
post #6 of 9 Old 05-29-2012, 08:18 PM
roddymcg's Avatar
I have used both Xantech and Speakercraft IR products. And thru several automation systems including Crestron, AMX, Control4, Savant, and RTI.
As mentioned some of the older boxes (H20/21 HR20/21 I believe) were a bit finicky. Offsetting the emitter helps with these boxes. So does poking a pin hole in some electrical tape and putting the emitter on the tape. I have also heard of guys using resistors on the emitter...
roddymcg is offline
post #7 of 9 Old 05-29-2012, 10:13 PM
egnlsn's Avatar
Quoted: 107 Post(s)
Liked: 60
I use a 15+ year old extender kit from Rat Shack and I have yet to have a problem that re-orienting the antenna hasn't resolved. I use a dual emitter that plugs into the receiver to feed my AVR, DVR, HDDVD Player, Bluray Disc Player, and OTA tuner. One eye taped onto the AVR and the other on the DVR gets them all.
CIAO!
Ed N.
egnlsn is offline
post #8 of 9 Old 05-30-2012, 09:42 AM
mdavej's Avatar
Quoted: 2063 Post(s)
Liked: 926
Thanks Jeff.
If you get an Xsight Touch instead of harmony, you can use RF directly with your D* DVR in RF mode and avoid any potential IR issues altogether, while still using RF to your IR blasters for everything else. There is zero lag on my Xsight.
mdavej is offline
post #9 of 9 Old 05-30-2012, 07:11 PM
egnlsn's Avatar
Quoted: 107 Post(s)
Liked: 60
I have that remote and love it. The only downside for me is that if you have 2 DVRs, you can't setup one for IR and the other for RF. I use 2 DVRs -- one IR and the other RF.
Other than that, it's been great!
CIAO!
Ed N.
egnlsn is offline
Reply Home A/V Distribution
