Nuvo Concerto? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-04-2012, 08:58 AM - Thread Starter
nobodeuno's Avatar
So I'm looking at picking up a used Nuvo Concerto system from a friend but I can't seem to figure out how to configure the system. Is there a way to obtain the configurator software from Nuvo or would I have to purchase it somewhere? I see a package for sale from Smarthome for $500 but that is more targeted at a technician who is going to sell their services, I am just looking to configure it for my home use. I sent an email to Nuvo support asking them but I figured maybe others here had been successful?
Also the Nuvo system I'm looking at comes with the NV-18DDSP keypads. Is it possible for me to use some of the newer keypads with the concerto system? Or how about the iPhone app interface? On their website they list these as accessories for the concerto but I wasn't sure if there were certain versions that they worked with.
Also I'm curious about firmware/software updates as well, are their any and how would I access the updates?
I am looking for a cheap way to enable my pre-wired home with whole-home audio. I have plans to do a more complete a/v distribution later on but the first step is a whole home audio. I haven't thought through everything yet but I am thinking about using an Airport Express to feed iTunes audio into the system...unfortunately I would have to use the remote app and I would loose control with keypads...still figuring everything out
Thanks in advance!
Justin
Oh and the unit I'm thinking of purchasing is the NV-I8DM, I see now that the one of their website is I8GM so I suspect there is a significant difference between the two...
nobodeuno is offline
post #2 of 10 Old 06-04-2012, 09:35 AM
jautor's Avatar
Quoted: 1303 Post(s)
Liked: 835
Yes, the software is available. There was a post here recently from someone that was given a link to it by NuVo Tech Support.
I assume this is the "IR Learning Station". You only need that if you had some component you wanted to control from the keypads, and it wasn't already in the Configurator database. Very unlikely you'd need this - mostly because most folks aren't controlling things like CD players through these systems any more... Most are using the streaming/digital music servers which are supported natively.
No, the newer keypads require the Grand Concerto. The iPhone app requires the music server. Not sure if the music server (and therefore the app) will work on the Concerto. But frankly, if you get so far as to buy the server, you'll want the GC anyway.
Concerto doesn't get updated anymore. But all NuVo products get their firmware updates via the Configuration SW.
How many zones? You might be better off with a small number of Sonos Connect:Amp units - NuVo also has a similar system "coming soon".
G = "Grand". Big difference...
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is online now
post #3 of 10 Old 06-04-2012, 10:41 AM - Thread Starter
nobodeuno's Avatar
Thanks so much for the information...that was very helpful.
I saw the thread you mentioned but the link seemed to be dead but maybe I was looking at the wrong link.
With regards to your question:
How many zones? I have every room in my house wired with speakers already so I think that is about 16 zones total But I was going to start with 8 or so...they are all going back to a central location. I will give the Sonos a look!
post #4 of 10 Old 06-04-2012, 11:19 AM
jautor's Avatar
Liked: 835
If you're looking at a potential of up to 16 zones in the future, bite the bullet on a Grand Concerto instead of starting with a Concerto or something else smaller. GC supports 6 zones easily, 8 with an add-on amps, and is expandable to 16 zones. Coupled with an MPS4 / Elite server, it's a really good setup...
(for the record, I have one, too)
Jeff
post #5 of 10 Old 06-04-2012, 08:33 PM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
I also have the Nuvo GC and mps4 music server. Great setup.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #6 of 10 Old 06-06-2012, 06:37 AM
Swancoat's Avatar
Quoted: 51 Post(s)
I do as well. I bought the MPS4 as a luxury, but it's almost a must. 98% of what we play on the GC comes from it. Sirius, Pandora, our own MP3's, etc... all with full metadata support. I love it like a child.
Swancoat is offline
post #7 of 10 Old 06-06-2012, 08:51 AM
Neurorad's Avatar
Quoted: 230 Post(s)
Liked: 145
MPS4 is my only source component for my Nuvo GC. Provides 4 streams, good enough for a family of 5.
Neurorad is offline
post #8 of 10 Old 06-07-2012, 01:28 PM
Swancoat's Avatar
Quoted: 51 Post(s)
Ha, my other two sources are:
-Airport Express (used to make 'announcements' etc... with HA system)
-CD Player, which is connected for two very good reasons - 1: I had a spare old CD Player. 2: I had an input remaining on the GC biggrin.gif
(However, as an exercise in having time to kill... I DID get the Nuvo to control the the CD Player through the IR port, despite not having the IR Learner station. I found the hex codes for the player on remotecentral or something and you can actually paste them into the GC configuration utility. I was (and still am) amazed that it actually works).
Swancoat is offline
post #9 of 10 Old 06-15-2012, 07:01 PM
fiteclub's Avatar
Quoted: 12 Post(s)
So does anyone know where or how to get the configurator software? I have the Nuvo Essentia system and tried to login to the "Prozone" site. Seems it does not exist anymore. I guess Nuvo is really trying to weed out the DIYers. Here is the link that used to work: http://www.nuvotechnologies.com/prozone.htm
I have the original Nuvo Musicport ( I still have issues with this device; I was getting help from Autonomic but now they defer to Nuvo whenever I ask questions and Nuvo just ignores me.
Nuvo: great hardware.....lousy service.
fiteclub is offline
post #10 of 10 Old 06-16-2012, 12:54 AM
jautor's Avatar
Liked: 835
Yeah, Autonomic is *supposed* to be working on an update to the Mirage SW, I've had some long-standing open issues with them, too. Mine works as long as I have the machine schedule a reboot every few days (as one of their services crashes whenever a Windows Update / Security Center update executes). I've thought about buying the MPS4 just to get back into the mainstream product, but kinda expect them to announce something new this year (CEDIA?).
The Prozone changed, but email Tech Support - they should give you a login to use to gain access to the software. I'm surprised that their new website doesn't even have the product manuals on it any more... The GC software hasn't changed much...
Jeff
Reply Home A/V Distribution
