How to test a used Niles ZR-4630 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-11-2012, 07:09 PM - Thread Starter
synbat's Avatar
I found a bargain on a Niles ZR-4630 and wanted to test it out before I buy. It only comes with a Niles R-4 remote, no other accessories .Once I connect a speaker to Zone 1, what key(s) on the reomote activates the sound for source 2 (I have a computer that plays music connected to source 2).
Thanks in advance.
synbat is offline
post #2 of 2 Old 06-12-2012, 04:22 PM
Greg C's Avatar
Well unless you have the Nikes Keypads, the unit will not do you much good. The remote is used to do 2 things: 1, Program the system by flashing the niles remote, such as enter, and then the OEM remote for cable let's say. 2, it will work if your keypad has an ir sensor to aim at with the Niles remote. Otherwise, the unit is a paperweight. You cannot use any other keypad with it.
Greg C.
www.pghcustomht.com
CEDIA University Designer CAT Member
CEDIA University Instructor
Crestron DMC-E
Greg C is offline
Reply Home A/V Distribution
