Wireless VGA streaming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-19-2012, 01:45 PM - Thread Starter
Rimski's Avatar
I have a device that outputs a VGA signal. It is in a remote location. I would like to take that output and send it via wifi to a computer. I cannot hard wire it.
Here is what I am thinking.
The device to accept the vga input converts the signal and has the ability to stream a live view via built in webpage. This same device has either wired(I can connect to wifi router) or wireless ethernet connectivity.
I would connect to the device vi IP and then open the web interface with a standard browser and view the live stream.
I know Epiphan produces devices that can accomplish this but they are thousands of dollars.
Can anyone recommend something a little less expensive?
Thanks for any and all assistance.
RK
Rimski is offline
post #2 of 2 Old 06-19-2012, 02:35 PM
Selden Ball's Avatar
Quoted: 3054 Post(s)
Liked: 1494
Exactly what is the device?
Most computers have only VGA outputs, not inputs.
If you've miscommunicated the input/output requirements, you might consider putting a very inexpensive computer at the location of the device and doing the video connection to your main computer using X-windows or some other remote display protocol.
Edited to add: StarTech is another supplier of VGA-over-Ethernet hardware, with units typically costing $150 to $300. They're even available from Sears wink.gif viewing it would be directly on a display, though, not in a browser.
Selden
Selden Ball is offline
Reply Home A/V Distribution
