Wireless Cable TV Extender questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-20-2012, 08:21 AM - Thread Starter
kmueller44's Avatar
Quick background: My dad wants to put a small TV in a room that is not wired for cable. He wanted me to research options for a wireless connection to his cable.
He has a comcast HDTV cable box about 20 feet from where this new TV is going to go. What are the options for making this work?
Would any of these do the trick? Any recommendations? Keeping in mind that I want to be able to keep the main TV hooked up to the cable box AND have the transmitter hooked up as well. Would some sort of HDMI splitter be required?
http://rflinkusa.com/products_WHD5001.html
http://www.actiontec.com/products/product.php?pid=219
http://www.aitech.com/products/wirelesscabletv.htm
My other suggestion to him was to get an iPad and a sling box, but that is a spendy proposition.
kmueller44 is offline
post #2 of 6 Old 06-21-2012, 09:48 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Either of the first 2 you listed should do just fine. If it doesn't have to be HD, you could get away with spending even less.
CIAO!
Ed N.
egnlsn is offline
post #3 of 6 Old 06-22-2012, 09:04 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I'm using the Actiontec with DirecTV and it works great (no line of sight required). Check out some of the reviews at Best Buy and Amazon though....it seems there may be compatibility issues with this device and Comcast cable boxes.
Vin
Vin is offline
post #4 of 6 Old 06-22-2012, 10:44 AM
cwpl's Avatar
How much does this one cost? http://rflinkusa.com/products_WHD5001.html
cwpl is offline
post #5 of 6 Old 06-22-2012, 01:52 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
Vin is offline
post #6 of 6 Old 06-22-2012, 02:17 PM
cwpl's Avatar
Thanks only place I didn't look, where I usually go first oddly. Knew it would be pricey
cwpl is offline
Reply Home A/V Distribution
